Author Topic: 1978 USA import CB550 K4 PD46C CARB  (Read 9231 times)
Offline Brian Cairns
« on: January 21, 2024, 03:32:11 PM »
I have got my self confused just wondering can you please check the picture and my identification oof carb parts:
1. air mixture screw (1 1/2 turns out)
2. Slow jet/pilot jet ????
3.main jet & emulsion tube
If identifications are correct, how do I remove slow jet, as I want to check sizes. Should be 42.
I checked main jet sizes, one was 98 and the other 3 were 90's. Obviously should all be same size.
Also what position should jet needle be? I am getting conflicting information on the web . Some say the needle can't be adjusted on the PD46C carb and some say they can?
Thanks in advance
Brian
« Last Edit: January 21, 2024, 03:45:54 PM by Brian Cairns »
Online Oddjob
Re: 1978 USA import CB550 K4 PD46C CARB
« Reply #1 on: January 21, 2024, 05:51:18 PM »
Identification is spot on. Take the mixture/air screws out and make sure they are intact. IIRC they have a really fine needle on the end of them, if you screwed them in too tight it would shear off in the carb body, there is also a spring a washer and a really small oring fitted on it. Spring on first, washer to stop the spring cutting into the oring, then the oring. You may need to fish it out of the hole.
The slow jet looks to be a push in fit, been many many years since I mucked with a set of those carbs so can’t say for sure how it comes out.
« Reply #2 on: January 21, 2024, 05:58:10 PM »
Brilliant! thanks so much.
Brian
« Reply #3 on: January 21, 2024, 06:35:49 PM »
I discovered that the slow jets are correct size ( 42) . They are push in and apparently designed never to come out! I won't mess with them.
I looked at airscrews , no washer or spring in any of them. Hopefully when i redo carbs the bike will run a lot better. The previous owner seems to made a hash of them. Bike hard to start and can't get over 65 mph......
Brian
« Reply #4 on: January 21, 2024, 06:50:22 PM »
The slow jets DO need to come out as bothe the jets and passAgeways block for a passtime, grip firmly with vicegrips and pull and twist at same time.
Refit with light tap from soft hammer.
EDIT
You can get replacements from Sirius Consolodated in canada along with the O rings and washers for the mixture screws but their website is a nightmare to navigate
« Last Edit: January 21, 2024, 06:53:10 PM by Bryanj »
« Reply #5 on: January 21, 2024, 07:11:08 PM »
EDIT
Ok will give it a go.
Brian
Offline SteveW
« Reply #6 on: January 21, 2024, 07:36:01 PM »
I pulled the ones out of my PD50’s by heating carb body with a hot air gun. Wrapped a pice of rubber tube around the jet and it pulled out pretty easy.
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
« Reply #7 on: January 21, 2024, 07:38:25 PM »
Will try that
Thanks'
Brian
Offline deltarider
« Reply #8 on: January 22, 2024, 08:11:28 AM »
A few pics that may help.
Online Oddjob
« Reply #9 on: January 22, 2024, 08:29:28 AM »
I did think you pulled them out TBH BUT I wasn't about to say grip them with pliers etc as it sounded a little brutal to me and likely to mark the outer part.
Glad to see my memory was right about the air screws, exactly as I remembered them, not bad for 40 odd years ago.
« Reply #10 on: January 22, 2024, 09:06:52 AM »
Probably not worthwhile just for a single job, but these Kniipex twingrip pliers have a "bore" in the nose that's particularly effective in gripping a cylinder https://www.amazon.co.uk/KNIPEX-82-01-200-atramentized/dp/B09FPZPY96/ref=asc_df_B09FPZPY96/?tag=googshopuk-21&linkCode=df0&hvadid=641638718575&hvpos=&hvnetw=g&hvrand=6235607503535841976&hvpone=&hvptwo=&hvqmt=&hvdev=t&hvdvcmdl=&hvlocint=&hvlocphy=9045915&hvtargid=pla-1640846664898&psc=1&mcid=e02a7d1495603634ba0636b3393dbad5&th=1&psc=1
Obviously a limited use here but very effective. Usually when you turn to get the pliers out something has failed, stuck or broken, these really do grip like hell to avoid slipping and seem a good addition to a toolkit.
« Reply #11 on: January 22, 2024, 09:18:25 AM »
Neat looking pliers.
« Reply #12 on: January 22, 2024, 09:40:20 AM »
Great !
Brian
« Reply #13 on: January 22, 2024, 09:41:16 AM »
Brian
« Reply #14 on: January 22, 2024, 09:45:48 AM »
Brian
