Author Topic: CB550 K3 Airbox Fittings  (Read 4214 times)
Offline PennoK3
« on: January 21, 2024, 05:51:45 PM »
I am very close to having all the bits I need to rebuild my airbox apart from the parts identified as Stay A and Stay B (threaded brackets for the airbox top).   I have one of them but I don't know if its A or B, is there a way to identify it specifically ?
Online mickwinf
Re: CB550 K3 Airbox Fittings
« Reply #1 on: January 21, 2024, 09:24:12 PM »
They are a different width where they fit in the recess in the airbox.
Offline 3scs
« Reply #2 on: January 21, 2024, 10:18:08 PM »
Stay A is the narrow one 20mm stay B is the wide one 30mm
Online deltarider
« Reply #3 on: January 22, 2024, 08:14:47 AM »
This does not refer to the airbox side, but to the correct orientation of the boots between the carbs and the head.
Offline PennoK3
« Reply #4 on: January 22, 2024, 10:16:44 AM »
Thanks all its Stay B I need then.   CMSNL have one for £14.00 which seemed reasonable (ish) but not when you add £15.00 postage!!!!!!
Online mickwinf
« Reply #5 on: January 22, 2024, 11:06:32 AM »
I might have the bigger one, will check later
Offline PennoK3
« Reply #6 on: January 22, 2024, 02:34:27 PM »
That would be great, many thanks.
