Author Topic: New member  (Read 17034 times)
Re: New member
« Reply #15 on: February 12, 2024, 10:12:26 AM »
I believe some of these units if not all have an exhhausts that vents to the outside so no issues with condensate from the fuel burning.
Yes, vents the exhaust to the outside, if you look at the picture you can see the exhaust system with a small silencer.
Offline Cb750r
Re: New member
« Reply #16 on: February 12, 2024, 04:16:07 PM »
I’ve been supplementing my shops heat with one of these this winter.
Fresh air intake for combustion, so it’s not consuming the oxygen from the shop and exhaust is routed outside. I have a carbon monoxide detector and have had no issues.
It goes through more diesel than the YouTubers claim, but it’s still a cheap way to raise temps to comfortable working conditions and because it’s not exhausting in the room no condensate issues either. I keep an electric heater in the shop to keep it above freezing, and turn on the diesel when I’m going to work in the shop.
