Author Topic: Front hub bearings  (Read 2567 times)
Offline DomP
Front hub bearings
« on: February 20, 2024, 08:17:01 PM »
When replacing bearings in a 550 front hub are they pressed in to place in the same order as on the rear, so retainer side first then the right side (non retainer side) until it just contacts the spacer?
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Re: Front hub bearings
« Reply #1 on: February 20, 2024, 08:21:30 PM »
Now I am confused I thought it was fixed side first ?
Offline DomP
« Reply #2 on: February 20, 2024, 09:12:18 PM »
I think Ted the idea is that the retainer clamps the outer race of the bearing against the base of the left recess then the right bearing is drifted in until the inner race touches the spacer.  This is to account for tolerances in manufacturing...I think
1975 XS650B
« Reply #3 on: February 20, 2024, 09:24:55 PM »
I meant the retainer side last, as you tighten the retainer it pushes the spacer out against the right side bearing?
Offline DomP
« Reply #4 on: February 20, 2024, 09:48:43 PM »
But that would leave the bearings able to shift sideways if not tight up against the bottom of the bearing recess
1975 XS650B
Offline DomP
« Reply #5 on: February 21, 2024, 08:10:24 AM »
I could be wrong, but that's how I was told the rear goes together.
Where's Bryan?😀
1975 XS650B
« Reply #6 on: February 21, 2024, 02:02:45 PM »
I always fit the fixed side first up to shoulderthen spacer and other side
Offline DomP
« Reply #7 on: February 21, 2024, 06:21:33 PM »
Oh so opposite to the rear hub method Bryan?
1975 XS650B
Offline DomP
« Reply #8 on: February 21, 2024, 06:58:37 PM »
I can't see how it can be any other way than retainer first, the otherside has no positive place to set a bearing to.
1975 XS650B
« Reply #9 on: February 21, 2024, 07:56:44 PM »
I thought the wheel axle spacers do that - if the floating bearing is right up against the shoulder when you fit the hub inside spacer as you tighten up the lock ring on the other fixed side bearing that will push the inside spacer up against the floating  bearing. A sort of pre-load before the axle outside spacers are pushed in as you tighten the axle nut.
In truth it might work either way, if Bryan says fixed first then OK - can't remember if this is covered in the Haynes Manual.
« Last Edit: February 21, 2024, 08:00:25 PM by McCabe-Thiele (Ted) »
Offline DomP
« Reply #10 on: February 21, 2024, 08:29:11 PM »
I've assembled the hub tonight, with bearings and spacer fitted it ends up flush on the right side in order that the retainer presses the left bearing up to its seat.  As I recall that's how it was when I disassembled it
1975 XS650B
« Reply #11 on: February 21, 2024, 08:34:14 PM »
Is that front or rear wheel Dom?
« Reply #12 on: February 21, 2024, 08:51:28 PM »
If you put pre load on single race ball bearings they dont last long.
I dissagree with regreasing them cos the only way to get them out is to hit the inner race to move the outer and that will damage both the races and the balls, remember only hit the race that is a tight fit
Offline DomP
« Reply #13 on: February 21, 2024, 09:22:28 PM »
Front Ted
1975 XS650B
« Reply #14 on: February 21, 2024, 09:31:16 PM »
Front Ted
That's how I did mine on my 400 Dom.
