Author Topic: CB400F Oil pressure switch slow leak  (Read 13097 times)
Offline Alexrayz
  • 1976 CB400F- Just making my way through the galaxy
« on: April 11, 2024, 06:56:30 AM »
Hello ladies and gents!
A year ago I had a slow oil leak at the oil pressure switch thread.
When running at temp I would lose a drop or two every five to ten minutes.
A degreased the oil pump housing, switch and the threads before putting
yellow loctite (577) on said threads.
It worked for 300km and started leaking again.
So I got a new switch. Turns out the OG one has replacements currently manufactured
and fitted on modern japanese cars. So yeah no need to spend 60€ for a used one on
Ebay as I previously thought.
Fitted said new switch without loctite (Wasnt mentioned in the holy book)
Then I tightened it as much as I could, that is until I got scared to strip something.
The bible does give a torque setting but impossible to fit a torque wrench in there.
3 months have passed with small rides, I washed it thoroughly for the first spring ride.
Still leaking a drop or two.  >:(
Have you fine people run into similar issues?
I would like to read your thoughts and opinions on the matter, maybe make this topic a compendium of OPS issues and fixes, who knows!
Cheers from across the channel! 8)
If it aint broken don't fix it
Offline ka-ja
  • ken
  • yoshi 460
Re: CB400F Oil pressure switch slow leak
« Reply #1 on: April 11, 2024, 09:58:30 AM »
strip, clean and try again with a decent sealer, say Hylomar? rolls royce compound.
nice bike,nothing in the bank
« Reply #2 on: April 11, 2024, 11:15:11 AM »
Or maybe a couple of turns of the white PTFE tape on the thread (just make sure it is only on the thread and not protruding on the end in case it blocks the oilway to the switch).
Online Mikep328
« Reply #3 on: April 11, 2024, 12:25:23 PM »
Is it possible that the pipe thread on the "modern" sender you purchased and the pipe thread on the moto do not match?  There are three or four different specs for "pipe threads."  I have no idea what Honda used in the '70's vs what they may be using now.  But if they don't match that could be a reason for the seep.
Mine:
1976 CB400F
1973 Norton 850 Commando
2015 BMW R9T
2017 BMW R1200RS
2021 Moto Guzzi V7 Special
Wife's:
2015 Ducati Diavel
2019 Honda Africa Twin
2019 Honda NCT750
« Reply #4 on: April 11, 2024, 12:32:40 PM »
It's been a while since I fitted mine FWIW I assumed they are a taper thread - if it is I would use some yellow grade PTFE tape making sure as has been said that you keep it off the end of the unit as Dave mentions.
White PTFE tap might be okay I have Yellow for when I used to do gas pipe fittings I believe it is more resistant to chemical attack.
When I fitted mine I just made sure the threads were clean and greased then just nipped them up - no tape used. Thinking about it Yellow tape might be too thick.
« Last Edit: April 11, 2024, 01:10:16 PM by McCabe-Thiele (Ted) »
Offline Athame57
« Reply #5 on: April 11, 2024, 12:46:14 PM »
Are you sure the source of this leak isn't actually the seal for the oil pump housing? I'm about to have mine replaced also, it was missing from the seal kit I got for a recent rebuild. Maybe it is a semi-orphaned thing?  ;D
I brake for animals!
1978 CB400F2 named Elen.
« Reply #6 on: April 11, 2024, 01:59:58 PM »
Its possible the housing has a small crack due to overtightening the taper thread or it could be the cover plate leaking, nurse julie does O ring kits for the pump
Offline Alexrayz
« Reply #7 on: April 20, 2024, 04:06:56 PM »
Hey everyone,
I haven't taken a look yet, I have been mainly investigating on the web. Will keep you updated
Offline Alexrayz
« Reply #8 on: May 20, 2024, 06:18:44 PM »
Hey everyone! I finally got to it.
I simply had the bike idle while the left cover plate was off to see where it was leaking from.
Surprise surprise it was the oil pressure switch again, from the switch to pump body thread AND from the eyelet screw thread on the switch itself,.
Guess I'm up for another switch, although I am not sure about which one to pick anymore.
I chose a new switch that is made today for several japanese/ asian automotive manufacturers. Honda lists it as the replacement reference for the original that was used in their 70's UJMs.
Those new switches are around 4 euros a piece, so it felt like a no brainer compared to the 40 - 70 euros originals on Ebay.
Now with the performance from the one  bought, I'm having second thought. Because the cherry on top of the crap cake is that the oil light came on like a minute or 2 after the bike was turned off.
Doesnt look like a quick switch to me, unless the oil does stay pressured well after the pump stop turning (???)
Looking forward to hearing from you all. I hope you guys get good weather!
P.S. : I found out that a motorcycle that won't turn over could be in need for petrol. Whou would've thought? I was already considering taking off my carbs for a clean  ;D ;D
« Reply #9 on: May 20, 2024, 06:50:18 PM »
I stock the Genuine Honda oil pressure switch, it's £29.99 - 10% discount + whatever the post cost to you, which isn't much.
Offline Alexrayz
« Reply #10 on: May 21, 2024, 01:08:22 PM »
Hey Julie thanks for the offer!
Are you sure about the postage costs to France? When I ordered my Hagon shocks I got something close to 80 euros in import fees...  >:( :'(
On a side note do you all have any idea what are the differences between the different switches available? The prices vary wildly, so I am curious if it is manufacturing quality or rarity or... etc
Furthermore, are OEM parts strictly better quality than aftermarket for these kinds of basic parts? I understand that the specs would be different between stock and AM for racing parts, but for basic general operation I don't know
Cheers!
« Reply #11 on: May 21, 2024, 02:51:32 PM »
International Standard is £5.45, no, or very little import duties will be payable. I send parts to EU regularly and never have issues, especially to France, Norway, Sweden and Denmark import duties are high.
As far as quality, something you pay £4.00 for is going to be substantially less reliable than a Honda OEM part. A lot of people sell car oil pressure switches for bikes but the pressures are different. Cheap Chinese shite is renown for not being very good, where OEM Genuine Honda oil pressure switches are tried, tested and reliable.
It's up to you Alex.
« Last Edit: May 21, 2024, 02:53:44 PM by Nurse Julie »
