Author Topic: Shockingly Fragile!  (Read 22554 times)
Offline Athame57
Shockingly Fragile!
« on: April 15, 2024, 09:48:29 AM »
Oh dear....what if I hit a POTHOLE?  :o
« Last Edit: April 15, 2024, 01:05:22 PM by Athame57 »
I brake for animals!
1978 CB400F2 named Elen.
Re: Shockingly Fragile!
« Reply #1 on: April 15, 2024, 10:19:58 AM »
Is that a genuine 400 rear damper you have found?
Offline Athame57
« Reply #2 on: April 15, 2024, 10:30:55 AM »
No, they are from Legend Motorcycles. Nice price too currently at £58.45 can't really lose!  ;D
 https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313&_nkw=cb400+four+shocks&_sacat=10063&_odkw=cb400+four&_osacat=10063
« Reply #3 on: April 15, 2024, 10:32:53 AM »
You would like to think they would be able to withstand a knock or two! 🤣🤣
Offline Athame57
« Reply #4 on: April 15, 2024, 10:56:24 AM »
I HOPE SO!  ;D
« Reply #5 on: April 15, 2024, 10:59:31 AM »
My shockers have a chromed shield on the top section - not sure if they are original or have been replaced in the past mine is a 1978(S) plated version.
Offline Athame57
« Reply #6 on: April 15, 2024, 11:03:06 AM »
I had a pair like that on mine when I first got her, but like many other parts they needed changing. This her from the we-sell-classic-bikes site. They are not original no, but if you like them you can get a pair on Ebay. Don't like them myself.
« Last Edit: April 15, 2024, 11:04:59 AM by Athame57 »
« Reply #7 on: April 15, 2024, 11:12:40 AM »
These are mine are they not an original design?
.400 lamp change 2 by Macabe Thiele, on Flickr
Offline Athame57
« Reply #8 on: April 15, 2024, 11:16:59 AM »
Beautiful customising! But no not original shocks. Here is Honda's own pic (?) of the model.  OK, that is the USA model but see the CMSL diagram....ditto!
« Last Edit: April 15, 2024, 11:27:15 AM by Athame57 »
Offline Athame57
« Reply #10 on: April 15, 2024, 01:04:39 PM »
This is what threw me, mine are working ok so only if they leak or fail will I change them for more genuine looking ones. This seller specifies 317 mm pin/fork as opposed to 315 mm for the more original looking ones.
The ones I've just fitted are also 315mm pin/fork but I've had to put some washers in for spacers, there was play.  :(  Blimey, this started as humour thread? Maybe it should be transferred!
« Reply #11 on: April 15, 2024, 01:15:07 PM »
Are you talking about fitting washer at the top mount for alignment or the lower fitting where it clamps to the swing arm?
I had to do some spacing at the top using some washers a member (allankelly1) made for me in SS.
« Last Edit: April 15, 2024, 01:18:35 PM by McCabe-Thiele (Ted) »
Offline Athame57
« Reply #12 on: April 15, 2024, 01:20:41 PM »
Where it fits to the swing arm.
« Reply #13 on: April 15, 2024, 01:42:51 PM »
Does your bottom mount have a threaded plate attached or is it a nut & bolt fitting?
Offline Athame57
« Reply #14 on: April 15, 2024, 04:40:59 PM »
It seems to be threaded without the plate. Whatever, tomorrow it goes into workshop to have a new oil pump seal ( missing from the seal kit I got for the rebuild I had) I'll persuade the mechanic to get me sorted.  ;)
