Author Topic: NGK plugs for 500  (Read 4222 times)
NGK plugs for 500
« on: May 15, 2024, 08:22:43 PM »
I have no idea when or where I bought them - I have a set of new NGK DR7EA plugs.
DS show the 500 plug as NGK DR7ES.
Can I use these DR7EA no idea what the S means compared to A ?
Online deltarider
Re: NGK plugs for 500
« Reply #1 on: May 15, 2024, 09:42:20 PM »
So far nobody knows. Why did you choose 'R' plugs?
« Reply #2 on: May 15, 2024, 09:45:17 PM »
I don't think ES are available,
The DR are resistor plugs
Could cause issues if used with resistor plug caps
That leaves D7EA,
Or if you ride harder D8EA
same as 400 and 750,
I use Denso equivalent, and an very happy
« Reply #3 on: May 15, 2024, 10:01:21 PM »
Ted, if you can find any D7EV are the dogs doodads for the 500, it should have had newish D7EA in it when you got it, D7ES is the original and not available the A is same as S according to NGK. You should not be using the R type
« Reply #4 on: May 15, 2024, 10:04:21 PM »
I have no idea, I can't remember when I bought them either.
I do have a set of Denso X22ES-U plugs.
I think my bike had  NGK D7EA fitted .
« Reply #5 on: May 15, 2024, 10:07:59 PM »
So a resistor spark  plug when you have resistor plug caps does this cause a problem somehow ?
Online deltarider
« Reply #6 on: May 16, 2024, 08:22:10 AM »
Not necessarily, but realise you'll then have a total of 20kΩ resistance in a circuit... Personally I consider that a lot and it is not needed. The French manual, that has been composed in colloberation with Honda France, advises to replace plugcaps when they read 8kΩ or more. Claims made by some members of the international forum - and nowhere else! -that adding resistance is benificial for spark duration, have so far remained unproven. And even then it remains to be seen it will effect in better running.
Offline Seabeowner
« Reply #7 on: May 16, 2024, 06:28:07 PM »
I ran resistor plugs and caps for years and didn't have a problem. I think DSS sells the R plugs for the 500. But I must admit I now use non R plugs.
My 71 500 came with 7.5k plug caps from new I believe.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
« Reply #8 on: May 16, 2024, 06:42:56 PM »
I've not experienced the purported problems that's often attributed to doing this either.
Often given out as a "No no" but without substantiated evidence to prove there's inherent problem by doing so.
I'd run them Ted, then you'll get at least personal experience of this with your own setup.
« Reply #9 on: May 16, 2024, 06:50:04 PM »
My experience on cars before individual coil packs arrived was that many used resistor caps and resistor plugs without problems with one coil on 4 & 6 cylinder engines so it's a new thing for me to consider it.
« Reply #10 on: May 16, 2024, 08:04:53 PM »
I have always used NGK resistive caps and non resitor plugs simply cos thats what the rep said, never asked why as he was very knowledgeable
Online deltarider
« Reply #11 on: May 17, 2024, 03:47:41 PM »
Two dealers in Holland that work on these bikes on a daily base have reported problems with resistor plugs on our bikes. Trigger has reported the same in: http://www.sohc.co.uk/index.php/topic,28181.msg264374.html#msg264374
It's a year old debate. I don't see any advantage whatsoever adding resistance over what NGK recommends.
« Reply #12 on: May 17, 2024, 06:41:21 PM »
Worthwhile trying them Ted, then you can form your own view and report the effects, if any, to forum for our appreciation  :)
Offline Toko_Jo
« Reply #13 on: May 17, 2024, 10:57:27 PM »
For a change I actually agree with you DR   :D
