Author Topic: Regulator/Rectifiers  (Read 5755 times)
Offline ropes
« on: October 01, 2010, 09:53:53 PM »
hi, I've got a Dresda cb750 with a K6 engine and need to replace the Rectifier and regulator. Does anyone have any experience of the replacement Regulator/Rectifiers that are advertised on Ebay and David silver etc... are they ok?? or should i try to get origional ??
Re: Regulator/Rectifiers
« Reply #1 on: October 02, 2010, 09:22:48 AM »
Rectifiers rarely fail unless damaged physicaly and regulators are adjustable, before replacing do all the checks in the manual to be certain what is wrong
« Reply #2 on: October 02, 2010, 10:05:48 AM »
I assume that you have the standard electrics?
I have a Dresda and the stuff under the seat is anything but standard...
Offline Yoshi823
  • Biker to the bone...
« Reply #3 on: October 04, 2010, 08:56:47 PM »
If you suspect the rectifier it's easily tested using a simple multimeter.
Connect the meter red wire to any of the three yellow wires, the black wire to the red wire. You should get a meter reading of a few ohms, if any at all. Now reverse the connection & there should be a reading of infinity.
Once you have checked in this way, then connect the red lead of the meter to the green (earth/chassis) lead, & the black wire to any of the three yellow wire. You should get a reading of a few ohms, if any at all. Do this to all three yellow wires.Finally, do a check across the red & the green, once with the red of the meter connected to the red lead of the rectifer with the black lead of the meter to the green of the rectifier. Check for any resistance other than infinity. Now reverse the meter leads...again there should be no reading.
For the regulator you will need a variable voltage supply across the input connections white & green/earth/chassis. Then, using a multimeter set to DC volts with the range set to up to 25vdc, connect between the black & the green, the black being the regulated +12dc output.
Now set the input volts to about 13vdc...& check that the output voltage is the same. Then increase the input volts until the output volts reading stabilises at the preset voltage...this is normally set by the factory. If the output voltage rises at the same rate that the input voltage rises, then there's a problem somewhere. There're adjusters for where the regulator switches, but I no longer have this information, which is normally found in Haynes or Clymer manuals.
If you are wishing to save space under the seat, i'd go for one of these...
http://www.electrexworld.co.uk/rr24-regulator-rectifier-604-0.html
If you wanted your units tested, i'd be willing to do this for you as I have the relevant test equipment.
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
« Reply #4 on: October 04, 2010, 09:21:59 PM »
Thanks for that Yoshi, very handy walk through of how to do it.
Must admit that I've not really had a problem in this area and saying that always hoped I wouldn't have to think about and tackle / analyse any probs with those two items.
Cheers.
Offline ropes
« Reply #5 on: October 05, 2010, 08:34:00 PM »
Thanks to everyone for their help. I'll give the exsisting bits a check over. It's just that when I got the bike it had suffered a fire in the loom and i want to know that the basic electrical system is going to be reliable when it all goes back together. I'll let you know how it goes.
Thanks again.
