CB500 cylinder studs
Topic: CB500 cylinder studs (Read 4126 times)
neat street
SOHC Expert
May 25, 2024, 10:08:00 AM »
Hi all, I am after 2 x cylinder studs for my CB500 and can`t find any anywhere? does anyone know of or has a couple that they would sell please.
#thank you
CB500 1975
CB750F 1976
KLX250 1983
Lambretta SX200 1979
Mini Mayfair 1984
neat street
SOHC Expert
Re: CB500 cylinder studs
May 26, 2024, 08:57:05 AM »
to be clearer, its the front ones part No 90034-323-005 (approx 13cm long), these are a little shorter than the rear ones :-)
thank you
CB500 1975
CB750F 1976
KLX250 1983
Mini Mayfair 1984
May 26, 2024, 12:36:57 PM »
550 are the same, they are a swine to remove and i do have one of those in bits, i will try and get some out next weekend
neat street
SOHC Expert
May 27, 2024, 08:39:26 AM »
Thank you Brian, the two in mine are broke and have to remove them, so far with welding nuts on, no joy, will leave them in soak for a week before I try again, realy appreciate your help..
CB500 1975
CB750F 1976
KLX250 1983
Mini Mayfair 1984
neat street
SOHC Expert
June 03, 2024, 11:31:21 AM »
managed to get both damaged studs out, and was not an easy task. welding was the only way for these two. one was right down to the end and welded a nut after leaving in soak of WD40 for a week, the other being longer also had the soak, but welded a longer strip of metal all the way down to the base giving more chance it would hold, and this one came out easier :-)
CB500 1975
CB750F 1976
KLX250 1983
Mini Mayfair 1984
June 03, 2024, 12:06:15 PM »
My dearly beloved wanted a patio extension so havent had time to go in garage and get studs for you yet, it is on my list though
neat street
SOHC Expert
June 04, 2024, 06:21:49 AM »
Thank you Brian, no problem, and family should always come first, no matter what :-)
CB500 1975
CB750F 1976
KLX250 1983
Mini Mayfair 1984
June 08, 2024, 04:00:10 PM »
I now have 2 front(short) studs removed and in a jiffy bag, pm me your details and we will agree how much!
neat street
SOHC Expert
June 09, 2024, 09:12:06 AM »
Thank you Brian
realy apreciate your time and help :-)
pm sent, paypal OK?
best wishes and thanks again
John
CB500 1975
CB750F 1976
KLX250 1983
Mini Mayfair 1984
