Author Topic: 400/4 heavy clutch  (Read 8486 times)
Offline ianmck
400/4 heavy clutch
« on: October 05, 2010, 07:55:33 PM »
My wife has started to ride my 400/4, she is having problems with the clutch, says its very hard to pull, I have to agree it is quite heavy, does anybody know of any simple cheap way of making the clutch pull a little lighter ?
1977 400/4 supersport.   1973 cb750 K4,
Online SteveD CB500K0
Re: 400/4 heavy clutch
« Reply #1 on: October 05, 2010, 08:07:07 PM »
Fit a new cable.
(worked for me)
Offline PatM
  • 2001 R1, Triumph 1200 and the little 400/4!
« Reply #2 on: October 05, 2010, 08:47:56 PM »
Oil the present cable- pour oil down  it and hold in vertical-in a vice or something- if rusty oil comes out after about 15mins- then it needs replacing. A hydraulic oiler is probably a bridge-to-far but it sure does squeeze oil down a stubborn cable.
Offline exvalvesetdabbler
« Reply #3 on: October 05, 2010, 11:46:30 PM »
Or the PO put heavy duty springs in.
I oil mine by disconnecting it both ends, get a piece of soft rubber pipe to fit over the top end and use a plastic syringe to push some thick oil down.  If it's clogged up with hard grease where it rests on top of the engine, squirt some paraffin through to clean it out first.
And put the other end in a container to catch what comes out!
Regards
Dave
« Reply #4 on: October 06, 2010, 05:07:17 AM »
If its a genuine Honda cable and its been oiled its knackered as the rubber inner sleeve swells up and interfeers withe the nylon outer liner.
Replace it with a Honda one (expensive but worth it) and DO NOT LUBE IT
« Reply #5 on: October 06, 2010, 07:38:16 AM »
I'm with Bryan on this.
If you have a genuine Honda cable, don't oil it (don't ask...)  :)
Offline florence
« Reply #6 on: October 06, 2010, 09:24:04 AM »
Might I suggest that the routing of the cable also greatly affects how it 'feels'.  Cables do not cope well with tight corners, such as where they go under the tank etc.  I always route mine so they as free as possible, using gentle curves and making sure they do not get trapped at extremes of steering lock.  I have found that, sadly, the original routing is not always the best.
Offline ianmck
« Reply #7 on: October 06, 2010, 08:25:44 PM »
Thanks for all sugestions, have re-routed the cable and cleaned and lubed, wife has tried it and says its better and will see how it goes. Will order a new cable from DS.
Regards to all and thanks again.
