Author Topic: 1976 CB 750 Clutch upgrade  (Read 4213 times)
Offline Sheps666
« on: July 23, 2024, 11:28:15 AM »
Hi we have a customer with a 1976 CB750 the clutch pressure plate the one with 4 springs has a crack in it can we use a clutch from a new Honda CB750 that will fit straight in with more springs.
Many Thanks Sheps
Re: 1976 CB 750 Clutch upgrade
« Reply #1 on: July 23, 2024, 03:49:44 PM »
Dont think so, those pressure plates crack when not fitted correctly and there is a form making better ones but cant remember the name
« Reply #2 on: July 23, 2024, 09:30:01 PM »
Many Thanks Sheps
Unless you've got something there, available and definitely fits, then I dont know of something with that replacement potential.
The early CB 750 is fairly unique in tbat design, with not much in the way of compatability from later type designs.
As noted above, the cracked spring plate on these comes from incorrectly assembled components, ultimately tightened down on springs with some internal misalignment.  Durability when correctly assembled isn't usually a problem with them.
Offline Sheps666
« Reply #3 on: July 24, 2024, 11:02:37 AM »
Hi,
 Thank you for the replies unfortunately this came to us broken where somebody just  but too many plates to stop it slipping.
Offline archmill
« Reply #4 on: July 25, 2024, 07:26:40 PM »
Sheps666, check with nurse julie, think she has new ones.
« Reply #5 on: July 26, 2024, 09:36:14 AM »
As above, possibly available to replace easily.
Generally though, they work well with parts in good condition.
Obviously a new lifter plate needed, set of EBC plates is good start point too. F2 model (the original not later re-use of name) from last SOHC 750 build used stronger clutch springs that can be substitute for softer original.  They give harder bite to original clutch pack but with stronger leaver pull.
Assembly of lift plate, tighten carefully with 1/4 drive socket set, pulling each one down equally as you pull plate tight in parallel to avoid snapping.
They "snag" if you've not got the alignment right as the assembly closes, you can feel this with small ratchet leverage as it bottoms out early STOP there and back out the bolts to check you've got it aligned properly. Don't keep winding them in and hoping. You may have to wriggle the plate you're pulling through from the rear by tightening to ensure it sts into engagement on its drive splines at the back of clutch pack, and not nose to nose on those spline.
Sounds more complex than it is, but taking time and care with carefully observation avoid damage. They're not big loads as you tighten and should bring suspicion if there's much in the way of resistance doing this.
« Reply #6 on: July 26, 2024, 11:04:15 AM »
Extra plates are not a good idea and dont work anyway,its sounds like it may have been assembled wrong by the owner, the rear plate with the 4 post can be fitted 4 ways but only 2 work in that the splines need to engage on the centre splines.
There are at least 3 different itterations of the 750 clutch and parts are not necessarily interchangable you will need to identify exactly what you have and get the correct parts or get a complete used assembly for that bike
