Try our re-instated info resource - "Aladdin's Cave" (Main menu)- sorry it's taken so long to fix
This is my oil of choice. It's meant for classic bikes in the first place.
I changed the oil to 10W40 mineral oil. Made no difference. I've adjusted the clutch lever free play from spec to virtually none to ensure the clutch is fully disengaged when the lever is pulled but there is no difference regardless of setting.
Could it be an issue with the clutch operating mechanism in the housing rather than the plates sticking ?The 400 has that odd triangular plate with the three ball bearings in - DS now does a replacement unit.
