Author Topic: Bullet connectors?  (Read 3680 times)
Online Mikep328
Bullet connectors?
« on: August 31, 2024, 02:39:54 PM »
I'm un-doing some strange wiring that the previous owner did on my
'76 400 and need a few of the correct size bullet connectors.  Is there supplier here in the UK?
Mine:
1976 CB400F
1973 Norton 850 Commando
2015 BMW R9T
2017 BMW R1200RS
2021 Moto Guzzi V7 Special
Wife's:
2015 Ducati Diavel
2019 Honda Africa Twin
2019 Honda NCT750
Re: Bullet connectors?
« Reply #1 on: August 31, 2024, 02:59:47 PM »
They are on e bay if you search for the size plus Kojaycat sell them.
I can't remeber the diameter I'll check one of my spares with my calipers to check the size.
They are 3.5 mm or thereabouts you can buy a box set that contains male, female & the insulation covers for M & F.
I belive some Honda models used 3.9 mm mine iirc were 3.5 mm.
Like these - mine were brass ones.https://www.ebay.co.uk/itm/152873651204?_nkw=vintage+honda+3.5+mm+bullet+connectors&itmmeta=01J6MCVPBMYSYV3NAZDWA2AJ06&hash=item2397facc04:g:uzAAAOSwx9ZavIqw&itmprp=enc%3AAQAJAAAA4HoV3kP08IDx%2BKZ9MfhVJKmJsMtXGvKCCgkd1Iqg9NWUAPrsvukLV%2FqqMK5AJpFPm%2FxGRfFEp23yvYyPSqIpOKU3xEvdTDCLjBq3cjE6dcoa2mhz6Z22lsBstpec1WGRn37BLsSMjMS%2BWq3bhzbTEO16Ma0Kj09z3K7xYBFSGpr5Kx%2FmxCdiXZRGiKqpZ2ZGWjVV3ffH9%2FAJRtnONyYfTYsTtEpdxvJhw6A%2FDUu5aMkFXP7E0nUHhs5CifeBmnllkAgDE9rHwHfIEJIndoNT5LjUX1YJRqxeF6%2BWEEZFVjNn%7Ctkp%3ABk9SR_Tl7oy1ZA
« Last Edit: August 31, 2024, 03:29:33 PM by McCabe-Thiele (Ted) »
Offline Deano400
Offline SteveW
« Reply #3 on: August 31, 2024, 05:42:02 PM »
Vehicle wiring products
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
Online Mikep328
« Reply #4 on: August 31, 2024, 06:55:20 PM »
Thanks guys, ordered the connectors from Kojacat!  :)
Mine:
1976 CB400F
2015 BMW R9T
2017 BMW R1200RS
Wife's:
2015 Ducati Diavel
2019 Honda NCT750
Offline ST1100
« Reply #5 on: September 01, 2024, 09:45:46 AM »
Link to Kojacat that Ted is referring to.
https://kojaycat.co.uk/epages/950000457.sf/en_GB/?ObjectPath=/Shops/950000457/Categories/Connectors_Bullet/3.5mm_Japanese_Bullet_Connectors
How is the material quality of those?
Got some bullet connectors (single and twin) here that seem made of rather thin brass sheets, hence don't latch very strong and can be pulled apart rather easy (especially compared to the OEM Honda ones...)
STOC #637
Offline BigAl (Alan)
    • www.alans-electrics.co.uk
« Reply #6 on: September 01, 2024, 06:28:50 PM »
I much prefer the bullet connectors from Vehicle Wiring Products... 3.9mm as top image. Solid material with a none shiny finish...gives a very secure fitting to the sockets.
The 'tinny' type bullets...3.5mm as lower image are slightly shorter and provide less crimping space for the wire/insulation termination.
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
« Reply #7 on: September 01, 2024, 06:44:05 PM »
FWIW when I fitted new connectors I used solder after crimping them.
I found using 3.9 connectors do not fit as they should if the switches or whatever are 3.5 m so I used 3.5 mm to match.
Yes you can switch them over if you want so they are all 3.9mm connectors.
« Last Edit: September 01, 2024, 06:46:15 PM by McCabe-Thiele (Ted) »
