Author Topic: Honda CB400NA Superdream - new money puddle.  (Read 197683 times)
Re: Honda CB400NA Superdream - new money puddle.
« Reply #255 on: April 12, 2026, 09:44:56 PM »
Good on ya Ted! Look forward to progress reports.👍
« Reply #256 on: May 13, 2026, 12:20:53 PM »
Just a bit of an update on the 400 Superdream, the frame is now in our back garden part sheltered from the weather with a Neverland cover to keep out the rain. The engine is on my bike ramp ready for some final preparation prior to painting.
The engine block paint arrived today, however the current cold spell here in Derby is preventing me from working in the garage until it's a tad warmer.
As Wendy's main Carer I have to priorortise her needs against my time in the the garage that I view as my respite from the daily routine that is part of our new situation. I'm working on a plan to manage in some formalised Wendy sitting so I can work guilt free in the garage. Next week is a meeting for me with a Cardiolagist to discuss the pros & cons of having a Pacemaker, no time scale as to the actual waiting list if we both say yes to the idea.
« Reply #257 on: May 13, 2026, 12:42:28 PM »
Not easy for you Ted but thanks for update and I’m sure just that little bit of 400 time will be a welcome distraction! Take care!
« Reply #258 on: May 13, 2026, 04:06:53 PM »
Are you 100% sure you will retain your bike license with a pacemaker fitted Ted? The medical questions on a license renewal these days specifically ask if you have one fitted so they must consider it some form of risk.
Waiting to see a Cardiologist myself, my ICU stay last year appears to have damaged my heart, still waiting to see how bad it is and whether it’s just damaged the wall or killed it.
Good luck either way, ring me if you ever feel the need to talk. I can talk for hours as we both know 😊😊
Offline Rozabikes Tim
« Reply #259 on: May 13, 2026, 04:45:46 PM »
This is spooky. Only thinking yesterday how Ted, Wendy and Ken were.
All th best to all of you.
« Reply #260 on: May 13, 2026, 08:22:08 PM »
Good point Ken about my motorbike licence, it's now on my list of questions.
« Reply #261 on: May 15, 2026, 11:48:58 PM »
Today as a test sample I painted the front top fin of my engine with Granville  satin black cylinder  paint.
Surface was cleaned with methyl accohol.
I spread it as thin as I could. Only one coat of paint advised as otherwise surface cracking might occur.
I suspect it must be white spirit solvent based as it said on the tin that what to use to clean your brush afterwards.
It's been about 12 hours since I applied the paint, not as black a finish as I expected, more like dark brown.
Tin was shaken & stirred thoroughly before application,  could it darken when fully dry?
Not sure if I like the look, might be better to use Simonize VHT silver as I have enough in stock.
Update AI seems to say it's blooming caused by moisture in the air plus too cold in the garage?
Any comments welcome.
#.trashed-1781432747-PXL_20260515_102208427 by Macabe Thiele, on Flickr
« Last Edit: May 16, 2026, 02:20:13 PM by McCabe-Thiele (Ted) »
« Reply #262 on: May 17, 2026, 01:25:03 PM »
It's less Brown now, still not pucka Black.
I'll remove it and wait for summer. 🤔
« Reply #263 on: May 17, 2026, 02:01:21 PM »
I’ve used Granville black on my cb1300 which has a black engine as standard. Very unhappy with how it came out. Can’t remember what I used to redo it but it was really good and lasted a good while. Was also a spray paint. It’s well known so others should be able to name it.
« Reply #264 on: May 17, 2026, 07:53:06 PM »
Simonize VHT engine paint  perchance Ken?
« Reply #265 on: May 17, 2026, 08:29:07 PM »
No I don’t think so Ted. I’ll spot the tin next time I enter the garage. It hurts to step down into the garage right now so I try and avoid going in there.
« Reply #266 on: May 17, 2026, 09:02:46 PM »
Thanks Ken, no rush.👍
« Reply #267 on: June 02, 2026, 09:05:49 PM »
For the last two days I've spent about an hour a day carrying out further cleaning of the engine unit in readiness for eventual painting.
The left side engine  cover has a gasket, presumably to keep the weather out of the alternator & associated electrics, it's a partial gasket as it does not extend to the drive sprocket part of the cover. This side cover looks as though it's  a polished finish.
Lots of caked on grime from the chain splatter, old gasket well and truly stuck to the casing in several places. When I've managed to remove all the grime it will be a few hours of using Ken's recommended little plastic discs before it goes on the buffing wheel.
It feels good to be working on the rebuild again even though it's likely to be only a few hours a week.
« Last Edit: June 03, 2026, 05:07:53 AM by McCabe-Thiele (Ted) »
« Reply #268 on: June 03, 2026, 07:41:19 AM »
Great to hear of a little progress Ted.
Offline flatfour
« Reply #269 on: June 03, 2026, 03:47:54 PM »
Perhaps a different situation, however an acquaintance of mine had a pacemaker fitted four or five years ago and, after a recuperation period, not only kept his car and motorcycles licences but was also able to continue driving private hire (taxi) vehicles and a minibus for a local charity.
