CB750
bearing shells
Topic: bearing shells (Read 3962 times)
roverboy
Newbie
bearing shells
January 27, 2025, 02:27:41 PM »
my bearings shells
Re: bearing shells
January 27, 2025, 03:30:46 PM »
What is the card calibrated in?
taysidedragon
Re: bearing shells
January 27, 2025, 05:06:19 PM »
It looks like thousands of an inch Bryan.
roverboy
Newbie
Re: bearing shells
January 27, 2025, 05:34:19 PM »
hi the gauge is in thousands of a inch
Re: bearing shells
January 27, 2025, 06:06:13 PM »
If the gauge is in thousandths you need different plastigauge as the smallest reading is 7 thou and that is waaaay too big for a Honda
Sesman
Re: bearing shells
January 27, 2025, 06:06:51 PM »
It tells me your big ends are fooked!
Re: bearing shells
January 27, 2025, 06:28:28 PM »
Not necessarily, the clearance is less than 7 thou but until the correct stuff is used we dont know the clearance.
You need to used Red plastigauge not green
Last Edit: January 27, 2025, 06:31:14 PM by Bryanj
McCabe-Thiele (Ted)
Re: bearing shells
January 27, 2025, 06:55:34 PM »
The wider the squash the tighter the bearing clearance.
Link to my full restoration
K2-K6
Re: bearing shells
January 27, 2025, 07:23:26 PM »
Looks approx 3 1/5 thou (0.088 mm) from that assessment.
McCabe-Thiele (Ted)
Re: bearing shells
January 27, 2025, 07:40:50 PM »
Iirc the Plastgauge I used was in a green package.
It was marked as 0.001-0.003".
0.025 - 0.076 mm.
Not sure if that is correct for your engine. Someone here will correct me if I'm mistaken.
CB750
bearing shells
