Author Topic: Smaller tail light fitting the original rear fender?  (Read 7679 times)
Offline alexdecker
« on: February 06, 2025, 05:27:09 AM »
Hey all
Does anyone know of a smaller tail light, that will fit the existing mounting point on the original fender (three or four holed) and has an OEM look?
I am replacing my old worn rear fender, and wanted to replace the tail light as well. I want an OEM look, but always found the whole rear end of a CB-XXX bike weirdly over dimensioned.
I am riding a CB550 F2 from 1977.
Thanks for any tips you can give me!
- Alex
Re: Smaller tail light fitting the original rear fender?
« Reply #1 on: February 06, 2025, 09:51:06 AM »
What light does that have at the moment?
Offline alexdecker
« Reply #2 on: February 06, 2025, 05:06:52 PM »
Its the original tail light, but the rear fender has rusted so bad and has holes in it because if it, and the tail light doesn't look good either, so wanted to get a new rear fender and then fit a smaller tail light on there if possible…
- Alex
« Reply #3 on: February 06, 2025, 08:48:09 PM »
I dont know which was the original on that, Honda used two different types
1 the original 500/750 type with cover held on with 2 screws
2 large type GL 100/ 750F2 type with cover held on by 4 screws
Which do you have, or post a pic
Online Oddjob
« Reply #4 on: February 06, 2025, 09:02:10 PM »
550F2 will be the 2 screw type, same as the 500 Bryan. It was the 550K3 which went to the 4 screw, massive tail light.
« Reply #5 on: February 06, 2025, 11:11:15 PM »
If its the smaller Honda one i personally dont think anything smaller is a good idea with todays traffic
Offline alexdecker
« Reply #6 on: February 07, 2025, 11:18:39 AM »
I have a picture of it here!
« Reply #7 on: February 07, 2025, 02:44:45 PM »
3’ wide for some of the drivers! 😳😂
« Reply #8 on: February 07, 2025, 02:45:52 PM »
Thats a US style tail light bracket so could be the big US style light, cant tell properly from that angle, does it look like the attached pic from the back?
Offline alexdecker
« Reply #9 on: February 10, 2025, 05:50:49 AM »
Weird, the bike is European. But the tail light does look like the image you attached!
« Reply #10 on: February 10, 2025, 05:56:02 AM »
The image is the small UK light, smaller is not available from Honda
