Author Topic: Steering lock Re-fitting issue on Superdream.  (Read 6440 times)
« on: March 15, 2025, 12:27:59 PM »
Before the frame was powder coated I removed the steering lock.
The rivet & washer came out relatively easily, the lock has clearly been replaced judging by it's as new condition.
I have had no issue on the 400 re-fitting the lock. I have the correct replacement washer & rivet, it will not however fit as it should. Rivet is 4.1mm in the manual.
The rivet is not a tight fit in the frame, my understanding is that when the rivet touches the end of the hole, it opens out when struck on the head splaying outwards to hold in place.
My thoughts are that it has possibly been drilled out in the past so the hole is possibly deeper than standard?
Any suggestions as to how I can now fit the lock?
« Last Edit: March 15, 2025, 12:45:55 PM by McCabe-Thiele (Ted) »
Re: Steering lock Re-fitting issue on Superdream.
« Reply #1 on: March 15, 2025, 12:52:47 PM »
I dont think it splays out Ted its just a tight fit like the vin plate rivets on the 500, possibly drill to a size to fit a lager one of that type mate
« Reply #2 on: March 15, 2025, 01:19:43 PM »
What size is the hole, try testing with drills until you get one that's a snug fit.
There's a specific name for those rivets but I can't remember what it is right now.
Try searching for hammer drive rivets, should be able to buy a slightly bigger one Ted.
« Last Edit: March 15, 2025, 01:21:43 PM by Oddjob »
« Reply #3 on: March 15, 2025, 01:25:57 PM »
Oddly enough Bryan the rivet is not a hammer in type like the VIN plate.
There are no serrations on the rivet that is a hollow tube like construction with a solid top end section.
There are slots in the side of the tube section to allow it to expand when you tap in the head part.
It's a sort of inverse Pop rivet.
As you say it might be worth trying to size a hammer fix alternative, I have a few different Pop rivets, might see if that could work.
Not a great photo but you can see it's hollow lower down in the slot.
PXL_20250315_132405364 by Macabe Thiele, on Flickr
« Reply #4 on: March 15, 2025, 02:15:03 PM »
The original would most likely have been the hammer in type with the spiral twist.
« Reply #5 on: March 15, 2025, 03:08:12 PM »
A hammer fit should be easy enough to find.
I found a suitable Pop rivet in my tin of such things, used in days gone by to attach metal trims to cars. Can't find my Pop Rivet tool that I probably last used 10 years ago.
The part from DS was in Honda Package 53603-051-000.
« Reply #6 on: March 15, 2025, 03:13:21 PM »
Ted the original rivet part shown on cms(steering stem page) is stated as a 4.1 mm and the pic shows it solid plus also used on CB500K so i recon the original was drilled out too big and something found to fit
« Reply #7 on: March 15, 2025, 04:17:36 PM »
Yamaha used what they termed a knock rivet, just remembered the term.
« Reply #8 on: March 15, 2025, 04:42:23 PM »
I kept the old rivet, clearly not original, it's pretty much the same as the replacement, just a tad fatter in the middle waist, where it has expanded.
