SOHC Singles & Twins
1976 CB250 G5 Float height for 745B Carb
Topic: 1976 CB250 G5 Float height for 745B Carb (Read 17691 times)
Re: 1976 CB250 G5 Float height for 745B Carb
Reply #15 on:
June 17, 2025, 08:54:05 PM »
The amount they hang down is of no matter as long as they shut off the fuel at the same level.
I can only assume that the tang to stop them hanging down too far is to make it easier to fit the float bowls, cant think of any other reason
Oddjob
Reply #16 on:
June 17, 2025, 11:18:50 PM »
I think it’s there to stop the float needle falling out if the float was able to fall as far as it liked.
rbt1548
SOHC Associate
Reply #17 on:
June 18, 2025, 09:33:37 AM »
Thanks, I'm just going to set them both at the same drop when vertical after ensuring that they both are the correct measurement when done the service manual way.
