Author Topic: twin disk front wheel  (Read 5664 times)
Offline polisher
« on: November 24, 2010, 12:18:27 AM »
Hi does anyone know if there is a twin disk spoked front wheel for the 750,  as i am building a chop and want spoked front instead of the F2 i have....... thanks......T
Dont polish it, Ride it.
Re: twin disk front wheel
« Reply #1 on: November 24, 2010, 06:49:21 AM »
Not that will fit with the forks/calipers/discs you have
« Reply #2 on: November 27, 2010, 12:41:33 PM »
My 400/4 wheel has holes all the way through the hub so it's easy enough to put a second disc on. It's mounted in 650 forks to give me caliper mounts and I've had to get new bearings & spacer made to make it fit. It's also relatively narrow, but that's not a problem for me.
So that would probably work. I'm not sure if the 550/750 wheels have holes al lthe way through the hub though. Anyone know?
Offline Yoshi823
  • Biker to the bone...
« Reply #3 on: December 13, 2010, 09:14:01 PM »
This might be hat you're looking for...
http://www.cmsnl.com/honda-gl1000-gold-wing-1976-usa_model7390/partslist/F++10.html
The 750 & 550 wheels did have the bolts going all of the way through the hub.
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
Offline polisher
« Reply #4 on: January 07, 2011, 08:16:19 AM »
excellent will try and source a 750 wheel and a goldwing wheel and see which fits best...T
« Reply #5 on: January 07, 2011, 02:10:47 PM »
Again neither with F2 discs, different number of bolt holes, nor calipers, different disc diameter
Offline cavapal
« Reply #6 on: January 09, 2011, 10:32:13 AM »
Hi, I'm in the same job, also own a 1978 F2 and trying to get rid off the comstar wheels, and repalce for a couple of wired ones.
Rear one, I think that the F1 one could fit, disc with 6 bolts, 296 mm same as F2 but I not sure about
the possiblity to use the same sprocket carrier.
Front one, the F2 has 2 disc of 276 with 5 bolts each, the F1 has 1 disc of 296 6 bolts, but as far as I know has also 6 bolts in the right side, in fact I saw K model with dual disc, but then the calipers on the F2 forks are in place for 276 discs, mmm >:(
Uploaded with ImageShack.us
I will follow up your progress also need to solve the problem...
