Author Topic: Brake lines  (Read 2554 times)
Offline Athame57
Brake lines
« on: July 01, 2025, 12:29:17 AM »
My brake lines are now seven years old. They feel ok, but I can't remember what they felt like new. There's no cracks or leaks but is it time to change them already, and is there something better than the originals to use?
1978 CB400F2 named Elen.
Re: Brake lines
« Reply #1 on: July 01, 2025, 01:04:39 AM »
If they aint cracked and not bulging under pressure they are safe to use, you can fit the braided nylon and even make them yourself with pipe and fittings from ebay
Offline Mikep328
Re: Brake lines
« Reply #2 on: July 01, 2025, 08:10:51 AM »
A suggestion - hold the brake line at its midpoint between thumb/forefinger and very firmly apply the brake.  If you feel ANY expansion in the brake hose, replace them with firmer lines.  I used HEL lines https://www.helperformance.com/home when I did extensive work on my brakes a couple of years ago.
Mine:
1976 CB400F
1973 Norton 850 Commando
2015 BMW R9T
2017 BMW R1200RS
2021 Moto Guzzi V7 Special
Wife's:
2015 Ducati Diavel
2019 Honda Africa Twin
2019 Honda NCT750
Offline Athame57
Re: Brake lines
« Reply #3 on: July 01, 2025, 11:31:25 AM »
Thanks everyone!  ;)
Re: Brake lines
« Reply #4 on: July 03, 2025, 03:03:45 PM »
If you do decide to replace the lines George you can get black sheathed braided stainless lines so they will look semi-original(ish).
