Author Topic: Bit of a leak  (Read 7205 times)
Offline DomP
Bit of a leak
« on: August 02, 2025, 03:47:04 PM »
Ive discovered a very slight drip from my rebuilt 550, its definitely coming from one of the lower oil passage caps which you can see in the photo.  I wanted to replace the orings under them when I did the rebuild but they were seized so rather than round the cap off I left them, regretting it a bit now.  Any tips on removal other that butchery and a new cap?
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Re: Bit of a leak
« Reply #1 on: August 02, 2025, 04:05:16 PM »
Worst case scenario Dom is start the bike with the cover off and they should blow out at a fair rate of knots
Oh and a shit load of oil
Ask me how I know!
Re: Bit of a leak
« Reply #2 on: August 02, 2025, 04:23:28 PM »
Obviously there's high risk on anything well stuck, of breaking, butchery etc .....
But .... these (or their type) https://www.ebay.co.uk/itm/305821836109 to flank drive it .... add to that a "hex to square" bit to fit in a drill with screwdriver clutch  .... you can gently rattle at it back and forth. They usually get something undone that feels impossible initially.
You can keep ramping the torque up to see what you get. takes time, but various vibration frequency often gets them to "talk" to you.
I've got quite a few, what look like completely lost causes, out by this method.
Even if it doesn't move it, then you can move on to a more potent impact driver if you've got one.
Offline DomP
Re: Bit of a leak
« Reply #3 on: August 02, 2025, 04:51:28 PM »
Different plug Roo, these are the 10mm hex ones from underneath the crank.  Too soft to get a good purchase on
1975 XS650B
Re: Bit of a leak
« Reply #4 on: August 02, 2025, 06:05:03 PM »
Aaah, my bad, I’ll get back in me box
Offline DomP
Re: Bit of a leak
« Reply #5 on: August 02, 2025, 07:07:45 PM »
1975 XS650B
Offline Seabeowner
Re: Bit of a leak
« Reply #6 on: August 02, 2025, 07:10:24 PM »
They can be $%%%^^ tight. I've only ever managed them with the six sided socket on a hand impact driver when the engine was out. Some may say that risks serious damage and not advise it though.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Re: Bit of a leak
« Reply #7 on: August 02, 2025, 09:54:18 PM »
For that price and for a full set Nigel it's a no brainer not to try them using the method you described, absolutely nothing to lose and good addition to the tool box👍
