Author Topic: CSMNL Exhaust for CB550 K3  (Read 26554 times)
Re: CSMNL Exhaust for CB550 K3
« Reply #30 on: October 05, 2025, 04:52:06 PM »
My 4 pipe Delkevic  exhaust came with new collets and clamps.
If you leave out the collets does number 2 pipe fit?
If you post the depth of your collett I'll check my original ones for comparison plus I have a set of SS ones via NJ that I did not use.
« Last Edit: October 05, 2025, 04:57:12 PM by McCabe-Thiele (Ted) »
Offline Gromitdog
« Reply #31 on: October 06, 2025, 09:29:11 AM »
Thanks to Ken,Gareth & Ted
Thank you for your suggestions will give them all a go it just seems that the N02 is giving me the trouble the others seem to kinda fit if only on a few threads. I will have a look in the bin to see if I got the old gaskets as they might just give me the couple of threads I need .
I did think of shorting the N0 2 collet by 5mm to see if I could get a better fit All my old collets are all different DIA wise (If that makes sense) but the lengths are all the same. Obversely the 4-1 system was not a straight fit either for the previous owners Just wish I had numbered the collets to which cylinder they came off of.
I will have another go to day and see keep you all posted to how I get on .................
Nige
KEEPING IT SHINY SIDE UP IS ALWAYS A GOOD RESULT ON A RIDE OUT
