Author Topic: Top Yolk  (Read 12407 times)
Re: Top Yolk
« Reply #15 on: October 20, 2025, 08:14:57 AM »
Make sure you have checked the appropiate partslist for your specific model. My CB500K2-ED, like the CB550K2, does not have these D washers anymore and has 7mm* instead of 8mm bolts.
* Tightening torque: 1,8-2,5 kg/m
« Last Edit: October 20, 2025, 08:54:59 AM by deltarider »
Re: Top Yolk
« Reply #16 on: October 20, 2025, 08:45:16 AM »
So does every other model with a replacement yoke, Honda superceeded the part without changing number
Offline Jond99
Re: Top Yolk
« Reply #17 on: October 20, 2025, 09:01:14 AM »
Xxxxx
« Last Edit: May 30, 2026, 12:06:08 PM by Jond99 »
Re: Top Yolk
« Reply #18 on: October 20, 2025, 09:03:48 AM »
38205-323-000 is a fuse-holder  ;)...it's a ---300---- part.
« Last Edit: October 20, 2025, 09:06:14 AM by AshimotoK0 »
Offline Jond99
Re: Top Yolk
« Reply #19 on: October 20, 2025, 09:25:46 AM »
Xxxxx
« Last Edit: May 30, 2026, 12:06:35 PM by Jond99 »
Offline florence
Re: Top Yolk
« Reply #20 on: October 20, 2025, 10:05:35 AM »
Just checked mine, washers are missing.  Was not aware of them being needed in 1995 when I put the bike together.  Evidently, I have been lucky.  I am planning to rebuild my forks soon as the oil seals have started weeping this year.  I will include washers.  Thanks for the warning.
Re: Top Yolk
« Reply #21 on: October 20, 2025, 01:10:59 PM »
Florence, depends on spanner size of bolts, if 10mm spanner its big bolts, if 8mm its smaller bolts
