Other Bikes
Will I ever learn?
Topic: Will I ever learn? (Read 12471 times)
Orcade-Ian
Will I ever learn?
December 05, 2025, 04:58:48 PM »
I was contacted recently by someone I didn't know, via a friend, who had found a dismembered motorcycle in the loft of a building in Shapinsay (one of the smaller Orkney Isles to the north of Kirkwall). His intention is to try to reassemble it but leave it with the proverbial 'oily rag' finish - something I certainly agree with in this case. It's a 1937 Panther 350 and according to the owners club is one of only a handful known to exist.
My task is to see if I can reassemble the engine, which has been stripped completely.
He sent some pics of what it looks like and an old tax disc shows 1951 - no pressure then! If it could be made to run, that would be a huge bonus - I see no good reason why it shouldn't.
Christine and I had a trip out on the ferry last Saturday to view this inanimate pile of scrap but I came back with quite a few parts to de-rust, clean and assess. It actually looks more promising than I first thought. A couple of frame parts are tied together with a Scarths label, which was a well respected engineering company here, sadly no longer with us and many of the skilled folk who worked there have also shuffled off.
Ian
Laverda Dave
Health is wealth
Re: Will I ever learn?
December 05, 2025, 05:36:35 PM »
Looks like you have some work ahead of you there Ian.
Are you going to start a thread, it will keep us all entertained during the winter👍.
Orcade-Ian
December 05, 2025, 05:53:21 PM »
I'll certainly post a few pics of the progress, so far the bore has cleaned up well (standard too), the piston is good and with new rings (available) will be fine. The flywheels have come up well, as have all the gears that go in the timing chest. It's actually quite a simple machine following most of the types I have worked on before and nowhere near as complicated as an LE Velo (or a Honda Four!). Even if it does run, it's not going to be thrashed up the motorway, so a bit of piston slap and burning less oil than a KH500 will be ok.
Being a rigid frame with girder forks simplifies matters too.
One problem so far is the appearance of spurious parts from other bikes/cars viz - two Triumph oil pumps in a box of carb parts!
That kind of serves me right for chucking a handful of nuts and bolts and springs into the boxes laid out in the maintenance department at Hawker Siddeley when I was an apprentice!
Ian
Last Edit: December 05, 2025, 05:57:48 PM by Orcade-Ian
Otis
SOHC Associate
December 05, 2025, 06:19:46 PM »
If anybody was going to reply to this post it would have ben Dave or Ian and i See that they did.
You certainly have a project ahead of you. The very best of luck with your project and ther are very many people on this forum that will happily help you.
Johnny4428
December 05, 2025, 07:08:41 PM »
Bravo Ian! An interesting project indeed. I would offer assistance but I don’t even have a blasting cabinet! Good luck I will maybe even visit to have a browse! 😜
Spitfire
December 05, 2025, 07:17:16 PM »
What a great project, saving that one will certainly keep you out of mischief.
Orcade-Ian
December 05, 2025, 07:24:48 PM »
No blasting will take place Johnny, just wire wheel and an oily rag. Steven has cleaned years of gutter from the very sound mudguards and sprayed them with Duck oil for now. Although the petrol tank is mottled with rust on the outside, many Honda owners would give their right arm for a tank as clean as this one inside! This is NOT a restoration but an assembly job to save a rare bike - with an original Orkney registration. Should be on show at next year's Vintage Rally, running or not.
Ian
December 05, 2025, 07:48:51 PM »
I didnt think the islands had enough lamposts for a panther, rumour was they only fired every other one!
Orcade-Ian
December 05, 2025, 08:50:24 PM »
You're right Bryan, so if there are no lamp posts, is that why it might not fire?
It's a crappy old magneto, so you know what that will entail! Might have to hide some modern electrickery in there.
Ian
December 05, 2025, 10:57:22 PM »
There arefewer and fewer people repairing magnetos now.
At lot of people dont know they have a condensor hidden in the windings and of course magnets can go weak
Orcade-Ian
Reply #10 on:
December 06, 2025, 08:45:16 AM »
Yes Bryan,
My tame magneto man went off in a wooden overcoat a good few years ago but a friend has just bought a kit to fit inside his mag and with a hidden battery all looks standard but with a reliable fat spark, so that could be the way to go methinks.
Ian
Laverda Dave
Health is wealth
Reply #11 on:
December 06, 2025, 09:19:33 AM »
There was a guy called Dave Lindsey who rewinds magnetos but he may have retired by now.
My old mate who I used to race speedway with used to rewind them, Ron Knight but again, long retired and sold all his equipment.
K2-K6
Reply #12 on:
December 06, 2025, 09:36:54 AM »
This place is worthwhile sending an enquiry to
https://www.robsonandfrancisrewinds.co.uk/
as I've used them before in larger motors.
Not specifically noting magneto, but possible they'll do that.
Orcade-Ian
Reply #13 on:
December 06, 2025, 09:50:20 AM »
Hi Dave,
Yes, I have had them done before by Dave Lindsley but I still think a modern electronic module fitted inside the present mag is a better option - discrete and reliable. We're a way off that yet - he's coming over with the cleaned crankcase halves today, so I can trial fit the r/h flywheel and all the gears in the timing chest. He is able to source a new crankpin/big-end bearing assembly, so the bottom end can be put together fairly soon, once I've assembled and trued the crank. All engine plates and bolts appear to be there but there is damage to the outer cover of the gearbox (a Burman) where the clutch release arm fits - that can be repaired here in Orkney. The clutch is another story!
Ian
Athame57
Reply #14 on:
December 06, 2025, 01:14:54 PM »
I thought these
Panthers
went the way of the Sabre toothed tiger
are you sure this isn't treasure trove?
I brake for animals!
1978 CB400F2 named Elen.
Other Bikes
Will I ever learn?
