Other Bikes
Yamaha CS5
5
6
7
Topic: Yamaha CS5 (Read 63897 times)
Johnwebley
Re: Yamaha CS5
Reply #75 on:
June 07, 2026, 03:56:34 PM »
the bike is now mobile,
refurbed the rear brake,greased pivots etc,re assembled and refitted
Johnwebley
Re: Yamaha CS5
Reply #76 on:
June 09, 2026, 08:46:10 AM »
Just had my registration returned,
Said I hadn't established the age sufficiently
I included specific details, explaining it was a stop gap model, only made in 1972,
But not enough,
I am sourcing a dating certificate from the Aircooled RD forum
Re: Yamaha CS5
Reply #77 on:
June 09, 2026, 05:25:36 PM »
They wont accept any "info" that does not come direct rom a recognised "official" source
Laverda Dave
Health is wealth
Re: Yamaha CS5
Reply #78 on:
June 09, 2026, 06:44:37 PM »
Have you tried the VJMC John. They do a dating service if you are a member.
Oddjob
Re: Yamaha CS5
Reply #79 on:
June 09, 2026, 08:23:51 PM »
Will they accept the manufacturers date plate Bryan. Gonna get round to doing the VT1100c soon. It’s a 1985 so just over the 40 year mark.
Re: Yamaha CS5
Reply #80 on:
June 09, 2026, 08:41:18 PM »
Not when i tried it Ken but if it has a V5c they should take the date from that but its a wierd formula something like from the April AFTER its 40 before January 1st, not 100% sure on specifics
Re: Yamaha CS5
Reply #81 on:
June 09, 2026, 10:00:55 PM »
Found the below on mr google
Oddjob
Re: Yamaha CS5
Reply #82 on:
June 09, 2026, 10:12:39 PM »
Well it qualifies under INF34 as it's a motorcycle. I'll have to look on the import form to see if the first registered date is shown.
Re: Yamaha CS5
Reply #83 on:
June 09, 2026, 11:34:30 PM »
If its an import you will need a dating letter Ken
Johnwebley
Re: Yamaha CS5
Reply #84 on:
June 29, 2026, 01:16:20 PM »
Quick update
After much headscratching,lots of splinters,
I was in the area of despairation
I decided to clean the comutator,
It looked good, no visible wear,
Using a narrow blade screw driver I cleaned the gaps,
Bit like under your nails,
Yes debris came out, good wash with cleaner,
Reassembled,
Tried it,starter worked better, charge light went out!
Successful
But, it didn't look like it needed doing
Picture of before doing
Re: Yamaha CS5
Reply #85 on:
June 29, 2026, 02:32:22 PM »
On the bigger stuff at sea Ted we used a ground hacksaw blade to undercut the segments, my aged memory tells me a motor is different from a generator on undercutting but cant remember how and it dont help on a dynostart that does both!
Johnwebley
Re: Yamaha CS5
Reply #86 on:
July 02, 2026, 08:11:41 PM »
Did a quick refurb on the front end
New rubber fork shrouds,
New oil,hardly any came out looked very thin,about half the amount that should be,
New tyre, same rim with patina
Bit of work on the brake, greased the cams,chamfered the leading edge ,they are reputed to be grabby,
Almost ready to ride
Re: Yamaha CS5
Reply #87 on:
July 02, 2026, 10:36:51 PM »
Looking good, that garage must be a bit full now mate!
Johnny4428
Re: Yamaha CS5
Reply #88 on:
July 03, 2026, 08:07:03 AM »
Ready to make some smoke!😜
Johnwebley
Re: Yamaha CS5
Reply #89 on:
August 14, 2026, 02:13:22 PM »
Ok,received the documents while I was away,
Number plate ordered,and fitted
So today the shake down runs started
Engine sweet,only 416 miles on the clock, so fairly careful running
Initially limited to 6k rpm,smooth, lots of power, speed about 60mph,
Lots of blue smoke, but reducing with the miles,
Rear brake ok,front brake poor, maybe the linings have been contaminated
Also fork seals leaking,
So far not bad,have done 50miles so far,
So I got a friend to show it off
5
6
7
Other Bikes
Yamaha CS5
