Crush Washers
Topic: Crush Washers (Read 6528 times)
Neilw
SOHC Member
Crush Washers
April 19, 2026, 10:47:27 AM »
What are Crush Washers, and where should I use them?
A lot of the bolts and nuts I've removed haven't had washers, which I feel can't be right!
Johnwebley
Re: Crush Washers
April 19, 2026, 11:27:50 AM »
The screws that have alloy washers are holding the rocker cover on,
Maybe more,
exvalvesetdabbler
Re: Crush Washers
April 19, 2026, 12:10:14 PM »
Usually places where you need the bolt to seal properly. Usually a soft material copper or aluminium.
Examples on 400/f
Sump nut
Front fork oil drain screw
Vacuum ports on cylinder head inlet
Allen screw that holds plunger inside front fork leg
There may be more
For high stress areas where a soft washer loosening off over time would be problematic there are steel washers that have bonded rubber inserts. Eg some cylinder head studs
Regards
Dace
Last Edit: April 19, 2026, 12:20:05 PM by exvalvesetdabbler
Re: Crush Washers
April 19, 2026, 01:51:52 PM »
Most important ones on 500/550 are
1 between angled bracket and rocker cover at ends. Alloy
2 between allen bolt and fork slider at bottom of fork. Copper
3 on bolt holding top of camchain tensioner alloy
There is also a thin steel shim washer that goes between the filter spring and filter in the housing that is frequently missing as it sticks to the filter and gets slung
McCabe-Thiele (Ted)
Re: Crush Washers
April 19, 2026, 03:30:07 PM »
I have found the parts manual the best reference point.
Link to my full restoration
Crush Washers
