Author Topic: Bike over heating after 40 mile ride  (Read 39737 times)
Re: Bike over heating often 40 mile ride
« Reply #15 on: May 02, 2026, 08:42:27 PM »
From this "Just to clarity when the bike died it would not even turn over until it had cooled down" do I understand correctly that it had partially seized, which stopped you turning the engine over ken4004  ?
Offline Ken4004
  • Semi retired hiding from wife in shed
  • Triumph Tiger sport 2013. Honda CB 400 4
« Reply #16 on: May 02, 2026, 10:21:52 PM »
It was like the starter motor didn’t even attempt to turn the engine over, in hindsight I should have tried the kick start.
There may be a possibility that there may not be a sufficient enough gap on the piston rings causing excessive friction as the engine heats up but I would have thought if that was the case the engine would have completely seized by now it had done 280 miles since the rebuild.
I would have thought I would have heard the starter solenoid clicking but as I said pressing the starter button absolutely nothing which is a bit strange.
Offline Ken4004
« Reply #17 on: May 02, 2026, 10:25:12 PM »
Setting the valve clearances today the engine turns easily as before, with an engine seizure you would think the engine would be difficult to turn over by hand at the nut on the points !
« Reply #18 on: May 02, 2026, 11:19:51 PM »
I think you have an electromechanical gremlin that stoped the engine and starter didnt work
Offline exvalvesetdabbler
« Reply #19 on: May 02, 2026, 11:54:30 PM »
Still in gear and clutch lever not pulled all the way in. We have probably all done it much to the annoyance of cars behind us.
Dave
Offline Skoti
« Reply #20 on: May 03, 2026, 06:43:23 AM »
That sets alarm bells ringing especially after a recent engine rebuild.
A partially blocked oil pump strainer gauze screen (possibly with surplus gasket
sealer etc) can cause restricted oil flow to the cylinder head, over heating and eventual camshaft seizure.
I'd pull the sump pan off and inspect the strainer gauze and check the oil filter at the same time.
Good luck
« Last Edit: May 03, 2026, 07:04:43 AM by Skoti »
Skoti
1976 Honda CB750F1
Offline Ken4004
« Reply #21 on: May 03, 2026, 07:10:31 AM »
anything is possible I am not ruling anything out and will continue double checking everything.
I think however that the issue is heat related at its root because it has never happen before in over 200 miles it was a hot day and the hill I went up was quite long and steep so if found out the weakness in the bike.
As I did day earlier once it had cooled down enough I took it easy and made it home without any issues so it’s a bit strange.
Offline Ken4004
« Reply #22 on: May 03, 2026, 07:13:47 AM »
Here is a picture of one of the spark plugs I took after I got home from my ride when it over heated, it looks normal to me but you might not agree .
Light tan colour which according to the manual is the normal colour , all spark plugs look the same.
I would call that black/sottey
OK you can see why I was looking at the needle heights to make it leaner
Offline Ken4004
« Reply #23 on: May 03, 2026, 07:31:06 AM »
I don't think fuel flow is the issue here, you're getting more than enough.
Time to check the easy bits before tearing stuff apart too much
Spare bit of pipe on the fuel tap into a clean recepticals and try the fuel tap in both pisitions
Choke flaps fully open once the leaver is clicked in the open position
Corrosion inside the post where the main jet sits, or fuel getting by the o ring
Float heights  are the float valves sealing or allowing the fuel level to rise too much
Clean plugs with a blow torch before trying again. There's always a risk that you have cleared the problem but not burned the crud off the plugs during normal running.
Sounds like you are going through the same mill I did 15 years ago.  I replaced all the brass ware in the rebuild kit but the needles and emulsion tubes are not in the kit.
Regards
Dave
Hi Dave when rebuilding the carbs I checked the float heights and they were all spot on, did have an issue with float valves and had fuel leaking out the drains so I have changed all the valves and all looks good .
I have drained the tank a couple of times through the tap and flow was good but will check again .
Can you please clarify what you mean by emulsion tubes ?
I am going on holiday for three weeks on Monday so running out of time but will pick this up again when I get back.
Would you be interested in meeting up when I get back for a coffee at a neutral venue it would be nice to meet you face to face, I am only in Copthorne near Gatwick and I see your only in Wimbledon so not far away from each other.
Cheers Ken
Offline Ken4004
« Reply #24 on: May 03, 2026, 07:36:36 AM »
When I checked the valve clearances there was plenty of oil around the cam shaft snd the oil light always goes out straight away but I will check the filter and gauze as I said earlier I am not ruling anything out, I don’t really find this frustrating just interesting and will get to the bottom of it.I see this as a learning curve the more I dig into this issue the more I learn so all good experience.
Offline Ken4004
« Reply #25 on: May 03, 2026, 07:57:19 AM »
Regards
Dave
Cheers Ken
Hi Dave sorry I was being a bit thick I know what you mean by Emulsion tubes , when I stripped the carbs they were all partially blocked with hard deposits. I have some very fine drill bits at home so cleaned out the holes with a slightly smaller drill bit and then followed through with the correct size without removing any of the tube material but they were pretty bad but they are clean on all carbs.
« Reply #26 on: May 03, 2026, 08:15:56 AM »
Good luck
It does for me too, and similarly feel caution in checking possible cause is time well spent.
My thoughts also go into running lean, the situation described with high heat long hill, flat spot (classic lean consequence) and motor coming to a stop. Then not re starting but free when cooled  .... suggest "nipped up" to me, if no poor oil supply etc that points to classic partial bore seizure.
Offline Skoti
« Reply #27 on: May 03, 2026, 08:27:30 AM »
Regards
Dave
Cheers Ken
Emulsion tubes on a CB400F, also referred to as needle jet set.
https://www.cmsnl.com/honda-cb400f-england_model14639/zestaw-igiel-odrzutowiec_16012377004/
I had the same symptoms on my F1 as Dave so nicely described on his earlier post above.
Went into denial mode when I saw the price, but when I eventually bit the bullet and renewed them it felt like I was riding a different bike. Very happy.
« Last Edit: May 03, 2026, 08:53:04 AM by Skoti »
Skoti
1976 Honda CB750F1
« Reply #28 on: May 03, 2026, 08:27:42 AM »
From the experience with my 400F over the past few years, the bike will run great on  E10 fuel with totally stock settings on everything - jet size, needle position, airscrew turns, STOCK type muffler and stock air filter/airbox.   As noted, leaving untreated fuel (without some sort of fuel storage additive) in the tank and especially in the carbs for extended period will have bad results.
I don't see particular problems either, but here with possibly lean mixture (flat spot etc) it could help compound any effects by containing more oxygen in fuel mix.
There's reasonable margin (there usually is on non accelerator pumped slide carbs) as they have to be set with bias to slightly rich to run correctly (the bog std setup) but with needles dropped plus E10, there's some measure of compound effect that eats the margin provided by standard settings.
My view is that these engine are very sensitive to being run in the correct air fuel range, when everything is fine. Outside that though, unintended consequential problems quickly build.
Offline Ken4004
« Reply #29 on: May 03, 2026, 01:03:25 PM »
I am always running the bike on E5 my Triumph I alternate between E5 and E10 so would that be E7.5 ( sorry little joke)
I have had a busy morning , removed exhaust and it’s clear, remove oil , removed oil filter, removed exhaust , remove sump and checked sump filter which had a little debris but nothing I would say would restrict oil flow around the engine.
All back together snd going to re do the timing and re sync the carbs and thats me done for the day.
