Author Topic: 1978 CB550 F2 Rear Light Query UK  (Read 2835 times)
Offline Neilw
« on: May 31, 2026, 09:30:35 PM »
I need to replace the rear light, as the housing is bent out of shape, and the lens doesn't fit correctly.
I've been trying to find an original housing, which I can see is a Stanley HM-11RC. The lens I have is a Stanley HM-15RC, which I can reuse
Should the two be the same, i.e. match, or can they be different?
I'm a bit confused what I should get - any help appreciated.
Offline Neilw
Re: 1978 CB550 F2 Rear Light Query UK
« Reply #1 on: May 31, 2026, 10:17:23 PM »
I've found that the HM-11RC is for older bikes, and the correct period part is the HM-15RC. Looks like I have a Frankenstein, correct lens, incorrect body.
I have located a reproduction part which will fit. Interesting that David Silvers is selling new, the HM-111RC for this model bike, which will fit, but is not the correct period.
Online Oddjob
« Reply #2 on: May 31, 2026, 11:20:55 PM »
The correct one for a UK version of the 550f2 is the smaller of the 2 fittings, has 2 screws attaching the lens. The K3 though got the much bigger one with 4 screws attaching the lens.
I seem to recall there was also a spacing difference between the mounting bolts so maybe you have the wrong rear light bracket as well.
Offline Neilw
« Reply #3 on: June 01, 2026, 12:46:18 PM »
I have the UK bracket (according to CMSL and parts lists). I think i have the incorrect light body, with the correct lens fitted to it. It's all good though, a replacement part is on its way - i was hoping to re-use the original lens, guess that will be for Ebay now!
« Reply #4 on: June 01, 2026, 02:31:50 PM »
The early lens wont fit the later body as its only half the size
