Author Topic: CB500-4 323 pipes baffle fix?  (Read 1677 times)
Offline JezzaPeach
  • CB500/4 K1 1972 gold
« on: July 05, 2026, 05:40:46 PM »
Hi, my original 4 pipes are very good externally, but the baffles are getting loose. Does anyone know if these can be repaired/replaced?
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
Re: CB500-4 323 pipes baffle fix?
« Reply #1 on: July 05, 2026, 08:44:47 PM »
Not easily as you would damage the chrome
« Reply #2 on: July 06, 2026, 04:39:33 PM »
I had an issue with one,
The baffle loose and vibrating inside the end trumpet,
I drilled a small hole, fitted small nut and bolt,used exhaust gunge to seal around the end,
Sprayed the end with satin black,
Took a lot of looking to see the repair
I think it was bottom right pipe
Offline JezzaPeach
« Reply #3 on: July 07, 2026, 05:58:31 PM »
Many thanks John. Unfortunately mine seem loose nearer the front of the box. I’m going to try my usb endoscope gadget to take a look, wondering if I could get some resin down there.
