Author Topic: Dismantling oil filter bolt  (Read 2172 times)
Online exvalvesetdabbler
« on: August 26, 2026, 11:42:22 AM »
I was just wondering if theres a wrong way to dismantle the oil filter bolt. It's one of those aftermarket ones with the larger hex. Been on the bike all the time I have had it. It's on my to do list for the next batch of zinc plating.
It looks like a case of compressing the spring and tapping out the roll pin?  Then spending the rest of the day looking for the bits that flew off into a dark corner.
Best regards
Dave
Offline Athame57
    • SeaWitch Artist
Re: Dismantling oil filter bolt
« Reply #1 on: August 26, 2026, 11:45:53 AM »
I'll be watching with interest, I may soon be doing it myself.
I brake for animals!
1978 CB400F2 named Elen.
Offline badger_eng
  • OK isn’t good enough. What If?
« Reply #2 on: August 26, 2026, 11:47:45 AM »
Did exactly same thing on my CX500 oil filter bolt although it went for cerakoting rather than zincing.
Yep, just tap out the roll pin. I just surrounded mine with a rag just in case of mass ejections.
Went back together dead easy also.
Current:-
Suzuki GSX-S1000GX+ - 2026
Suzuki GT500A Cafe style - 1976
https://www.kettleclinic.co.uk/kcforum/viewtopic.php?t=14273
Honda CB550K - 1977 (Winter 2026/27 project)
« Reply #3 on: August 26, 2026, 11:54:53 AM »
Why??
Just give a good clean, Using a brake/clutch cleaner and polish the head
The rest is hidden
Offline badger_eng
« Reply #4 on: August 26, 2026, 12:05:37 PM »
Because it wasn’t hidden.
And…… even if it was hidden, I would still do the same.
We all have our ‘isms and some ‘isms may differ from yours.
Apologies for starting a sentence with both Because and And! I will self flagellate later 😬
Current:-
« Reply #5 on: August 26, 2026, 12:39:41 PM »
There is evidence of some aftermarket oil filter bolts being assembled wrong. I've done a few of the bolts now, it's fairly easy. However getting the insides to slide easily down the tube can take a little doing. I can't remember exactly now how they are supposed to be assembled but lets say it's plug, spring. Some of David Silvers bolts were spring, plug. Meaning they wouldn't work as they were meant to. In fact they wouldn't not work at all. Or they'd be permanently reducing the oil pressure by opening areas not meant to be opened except when the filter blocks. I've also found pressure relief valves on the oil pump itself jammed solid. 3 out of 4 were stuck in place.
It's where I find the little plastic wheels I use on my Dremel come into their own. You can use a really fine grade of wheel to essentially polish the components to allow them to move very freely when needed. Very easy to do with no effort at all.
Offline badger_eng
« Reply #6 on: August 26, 2026, 12:45:37 PM »
Mine was the original Honda type Oddjob. Knowing me, I would have photographed it as I went along (kiss of death that statement eh)
If needed, I can trawl the archives and send on to whoever needs.
Just let me know if required and I’ll check on the comp 👍
Current:-
« Reply #7 on: August 26, 2026, 12:55:35 PM »
Just found my stash. I have 3 disassembled. Just a cup like plug and a strong spring along with the roll pin. I must have left them dissembled in order to zinc plate the bolt but my illness last year put paid to that. I did however find an oil filter washer in the same box, that made me look around and find an exact copy in stainless steel so I ordered 50. I'm doing a 1976 Kawasaki Z100A1 at the moment for my brother in law, I found that just like Honda they also used the same type of washer to prevent the spring under the filter from going through the rubber grommet in the filter and of course his was missing. I had to make one out of a gearbox thrust washer as they were no longer available even from specialists like Zpower. I think it's spring in first, followed by plug. Then held in place by roll pin. That would mean the plug would be exposed by the filter spring and thus able to be forced back against the oil pressure and so allow openings in the filter bolt being exposed and allowing oil to bypass the filter in the event of a blockage.
Offline Athame57
    • SeaWitch Artist
« Reply #8 on: August 26, 2026, 05:31:11 PM »
Eeek! Mine is a DSS one too.  :o  I entered this thread thinking of something else, I've never thought to take a closer look at the bolt but I will now. If it is in right, ok but how to test? I'd rather not be pulling apart, knowing me at best I'll need my big magnet to hunt missing pin, or at worst I'll end up with an eye patch like Long John silver, never mind David Silver.  ;D
I think I'd rather take  a leaf out of John Webley's book.
Offline badger_eng
« Reply #9 on: August 26, 2026, 05:37:46 PM »
The schematic is correct
The cap is nearest the hex on the bolt, followed by the spring. Both then held in place by the roll pin.
No stress…. easy peasy job to do.
Current:-
« Reply #10 on: August 26, 2026, 06:04:32 PM »
Yeah that makes sense. For some reason I was thinking the filter went on the bolt first but of course it doesn’t.
Offline Athame57
    • SeaWitch Artist
« Reply #11 on: August 26, 2026, 07:19:24 PM »
But what does this spring within the bolt actually do, if there is a pin crossing the circle of the spring? What and how to check?
Offline badger_eng
« Reply #12 on: August 26, 2026, 07:28:01 PM »
Its a bypass / pressure relief. If the filter becomes blocked, it moves allowing free flow of unfiltered oil to continue around the engine
Current:-
Offline badger_eng
« Reply #13 on: August 26, 2026, 07:29:17 PM »
The spring compression rating will allow it to compress at a certain PSI.
Current:-
« Reply #14 on: August 26, 2026, 07:32:09 PM »
The spring sits on the roll pin, it pushes against a small metal cup, with the spring sitting inside the cup. The cup blocks holes in the filter bolt, however if the filter collapses or blocks enough to stop oil flow the pressure of the oil pushes the cup down against the spring pressure and that means the holes it was blocking are now exposed. The oil uses these holes to bypass the filter so stopping the engine from seizing. Get a small sharply bent piece of metal and push down on the cup, it should move, if it doesn’t you have a problem and you’ll need to dismantle the bolt to free it off.
