SOHC.co.uk Forums > CB500/550
CB550 Neutral Switch
<< < (3/3)
Neilw:
--- Quote from: Oddjob on September 25, 2026, 03:00:18 PM ---Got to have some left of the plate after the bend for that to be a solution Johnny I’d imagine. I’m looking at replacing the entire plate.
--- End quote ---
Inspired by your good self, i decided to remove the two rivets to see what's involved in replacing the whole plate.
It all came apart relatively easily after I ground the rivet heads down. I've managed to source some 0.3mm Phosphor bronze spring sheet quite cheaply and some M2 Solid Aluminium Rivets. I'll use the broken one as a template and cut and bend the new one from the plate. Sounds and looks simple - what could go wrong!
Thanks to BryanJ I also have a Rotor arriving, so hopefully i'll be good to go.
McCabe-Thiele (Ted):
--- Quote from: Neilw on September 25, 2026, 05:33:53 PM ---
--- End quote ---
--- End quote ---
Don't forget you need some sort of contact as well, iirc the original has a hole where it fits on the prong end.
Oddjob:
Almost my idea exactly Neil. I went for 0.8mm copper sheet though as I wanted some substance in the plate. I’ll drill a small hole where it makes contact with the rotor and fit a small copper rivet there which should help with any wear issues. Just waiting for the copper sheet to arrive, already have the copper rivets for some reason.
It will be interesting to see the finished repair photos from either of you.👍
Johnny4428:
--- End quote ---
Yes Ken, it was just the main contact protrusion gone  leaving a hole in the end of the contact plate.
Navigation
[0] Message Index
[*] Previous page
Go to full version
