Try our re-instated info resource - "Aladdin's Cave" (Main menu)- sorry it's taken so long to fix
You need to keep some choke on for a couple of minutes until the engine warms up enough to run without it. It will stall without any choke when cold. Gradually reduce the choke to keep the revs from rising as the engine warms.
Quote from: taysidedragon on September 30, 2026, 04:22:05 PMYou need to keep some choke on for a couple of minutes until the engine warms up enough to run without it. It will stall without any choke when cold. Gradually reduce the choke to keep the revs from rising as the engine warms. This is only true for models that have the PD carbs. The older models with 069A carbs are not supposed to start riding with the chokes partially closed. A raised idle enough. That's why the K3 had the choke knob positioned at the handlebar in the view of the rider. Earlier models had a choke lever on the left side of the carbs and Honda did not intend you to take your left hand from the handlebar to feel around for and fiddle with a lever somewhere below. Honda's idea for safety first and hence it is in the starting procedure in the Owner's Manual.
Quote from: deltarider on September 30, 2026, 07:49:20 PMQuote from: taysidedragon on September 30, 2026, 04:22:05 PMYou need to keep some choke on for a couple of minutes until the engine warms up enough to run without it. It will stall without any choke when cold. Gradually reduce the choke to keep the revs from rising as the engine warms. This is only true for models that have the PD carbs. The older models with 069A carbs are not supposed to start riding with the chokes partially closed. A raised idle enough. That's why the K3 had the choke knob positioned at the handlebar in the view of the rider. Earlier models had a choke lever on the left side of the carbs and Honda did not intend you to take your left hand from the handlebar to feel around for and fiddle with a lever somewhere below. Honda's idea for safety first and hence it is in the starting procedure in the Owner's Manual.The choke is not an on/off switch.
The fuel tap is down on the left hand side of my bike and I have no problem turning it to reserve while riding.
Hold on tight folks for yet another long thread.Here we go again with more on the air screw myth...
Just an Update - and honestly you just can't make this up!The overspill has gone, as far as i can tell from carb 2. UI dropped the height of the external fuel tank and got set to go.Tried to start the bike, but it just wouldn't fire. Cleaned the plugs and went to go again, but the Battery is dead!. So I had to order a charger and let it charge overnight.Full of hope this morning, I reinstalled battery and fired her up, of rather it didn't want to fire. Popped plug 4 out and there was no spark, tried 3 and there was. put 3 back, started the bike and it sort of jumped into life briefly before dying, now no spark there either.I've spent the morning testing and it seems it could be the coils, i'm not getting the readings the videos say I should, but as the language is not consistent across the videos i don't 100% know if i'm checking the right wires with the multi meter at the coil. Basically, I get 0 when connecting the MM to the yellow and black/white wire coming out of the coil and the same for the Blue - Black/White combination. Is it possible for both Coils to fail at the same time?So i can't even get the bike started to see if the carbs are any better! FML lol!
I don't know how long you have left the ignition on for, I'm not 100% certain but it's very unlikely that both coils would be cooked, only the one where the points were closed possibly. In the past I've left the ignition on overnight (on a car), the battery was flat, the coil body was hot, when it all cooled down it was OK again.
It’s well known if you leave the ignition on and the coils energised they are prone to burning out Ted. It’s not common as it requires some time to happen but it does happen now and then. Other than the leads they are almost indestructible.
