Author Topic: CB550 neutral indicator light  (Read 3043 times)
Offline Rolfbulmer
« on: October 01, 2026, 08:48:16 AM »
The neutral switch and indicator light works perfectly when the bike is cold, however, after about 6 miles of riding the neutral light comes on and stays on. Once the bike has cooled down, the light behaves perfectly again. Mechanically all looks good with the switch and electrically it is all correctly wired with all connections good. The bike has been rewired using an motogadget m-unit.
Any ideas as to what may be causing this please.
1977 Honda CB550F - Cafe racer project bike
2001 Honda Hornet 600  - All weather bike
2019 Triumph Speedmaster 1200 - Dry and sunny weather bike
Re: CB550 neutral indicator light
« Reply #1 on: October 01, 2026, 09:22:04 AM »
Have you trapped the wire when fitting the engine side casing, easily done.
I had a similar issue, the wire was squashed and put the light on when the engine warmed up.
« Last Edit: October 01, 2026, 09:23:36 AM by McCabe-Thiele (Ted) »
Offline Rolfbulmer
« Reply #2 on: October 01, 2026, 07:48:29 PM »
Interesting thought. I'll have a look over the weekend, thanks.
« Reply #3 on: October 01, 2026, 07:55:25 PM »
Sounds to me like the mod unit is wrong
Offline Rolfbulmer
« Reply #4 on: October 01, 2026, 08:06:06 PM »
Hi Bryanj,
Excuse my ignorance, but what do you mean by the 'mod' unit?
« Reply #5 on: October 01, 2026, 09:25:12 PM »
Modification from standard, i dont trust the m unit
Offline martin_uk
« Reply #6 on: October 04, 2026, 02:01:22 PM »
It is a good idea to familiarise yourself with the normal operation.
The neutral circuit operates using ignition switched power to the warning light (+) and the neutral switch grounds the other wire (-) to light
As Ted mentions, incorrect illumination can be caused by the switch wire being shorted to ground some where along length or even at bulb end or a faulty switch causing it to ground when not in neutral
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
