Author Topic: Finally found a quick action throttle for my CB500 four  (Read 344 times)
Offline Nashfly
« on: October 30, 2026, 09:06:24 PM »
I've been looking for a quick action throttle for my RC181 Replica for a while
I have been using this:
https://good-bits.co.uk/product/throttle-control-honda-cr-style/
It works very well, but still needs a couple of handfuls to get to full throttle. I only used the pull cable, but the push could be fitted as well
After much research, I saw this for a 1994 - 2003 CB500 twin:
https://www.sfpartsltd.co.uk/quick-action-throttle.html
Thinking it may fit, I ordered it, along with a throttle cable for the same model. After a bit of tweaking it fitted (I used the red, larger ring)
I tried it out this afternoon and it was brilliant, about a quarter of a turn from tickover to fully open. I was worried about the strength needed, due to the Honda's connecting rod set up, but I compared it to my TZ Yamaha, fitted with twin Mikunis, and it felt about the same
Pull cable only and I think this may work on the CB750's as well
Note, both these throttles will not work with the Honda switchgear and there is a quick action throttle here that might:
https://www.ebay.co.uk/itm/277981194483
Hope this helps someone
Pic of my bike at the Stafford show:
« Last Edit: October 30, 2026, 09:10:37 PM by Nashfly »
Offline florence
Re: Finally found a quick action throttle for my CB500 four
« Reply #1 on: October 30, 2026, 09:50:10 PM »
Riding back from work today I was thinking about the same thing so thank you, will investigate this.
Offline florence
« Reply #2 on: October 30, 2026, 09:53:49 PM »
I have the CG125 throttle cable on mine to account for the bigger handlebars.  I wonder if compatible with this twist grip?
Offline Nashfly
« Reply #3 on: October 31, 2026, 09:14:09 AM »
Thread for fitting to throttle is m10 x 1.50 -  nipple is 6mm diameter 7mm long
Thread for fitting to carbs (adjuster) is m6 x 1 -  nipple is 6mm diameter 10mm long
Online Oddjob
« Reply #4 on: October 31, 2026, 12:05:20 PM »
I did a whole thread on this subject a couple of years ago now.
There used to be a quick action throttle setup back in the 80s. It used a separate housing that slid on the bars between the switchgear and the grip. You blanked off the cable holes in the switchgear and used the ones in the new housing, that had a far larger boss like your red ones inside. It worked but looked a little out of place TBH.
My solution was 2 fold, enlarge the boss where the cable nipples go in, I found the CB1300 throttle pipe was ideal, bigger boss and just fitted inside the switchgear, that reduced the pull movement by around 16% IIRC, then I made a new butterfly for the carb shaft. All told I think I reduced the throttle movement by about 30% with both measures. Like all of my little projects they all halted last year when ill health stopped play. Now that I'm finally starting to improve I may go back to it, with a lathe or access to a friendly engineer who is willing to do the work for me I can make a new butterfly that looks better whilst doing what it's supposed to do.
