Author Topic: Oil filter housing O Ring keeps blowing out  (Read 1312 times)
Offline Anderzander
Re: Oil filter housing O Ring keeps blowing out
« Reply #45 on: November 16, 2026, 08:15:12 PM »
I would recommend a borescope to check and clean out the galleries.
Whatever is in those galleries will go straight into your bearings when you start it up and my experience is that it take a lot to get them clean.
This wasn’t a CB engine (not even a bike engine in fact) but the last engine I rebuilt I had steam cleaned the galleries, put a paraffin gun through them, and blew them out with compressed air very thoroughly and the galleries were still full of chips (pic1). So I bought stainless brushes for cleaning gun barrels that fit onto a drill and ran those up and down, then wrapped the brushes in lint free microfibre cloth and finally they came clean (pic2).
CB750 K3
« Reply #46 on: November 16, 2026, 10:13:43 PM »
Hi Johny,
I dont know anything about your bikes history, your level of experience etc, so please forgive me for asking some basic questions about your rebuild, I'm not doubting your ability, I just do not know how experienced you are so please do not be offended by my questions, I am trying to help here.
Was the bike a runner when you bought it?
Do you think the engine casings have been seperated before?
TBH I can't see a bit of debris at one end of an oil gallery causing the oil filter housing seal to blow, there is a bypass valve in the oil filter housing to cater for a blocked oil filter, there is a pressure valve on the oil pump to regulate the maximum oil pressure.
if the oil pump valve was at fault, I would expect it to have been very difficult to remove the valve from the pump body, was it?
What are the crank case codes what colour shells did you fit?
Did you Plastigauge the crank shells for clearance?
« Reply #47 on: November 16, 2026, 11:39:47 PM »
I repeat the only thing that can cause excess oil pressure is a failed or blocked oil pump relief valve, there is nothing else to cause it
« Reply #48 on: Today at 07:29:56 AM »
I agree with that Bryan, so the next question is how big would a blockage in the oil galleries have to be to still blow the seal?
A blockage after the oil pump in the galleries should not blow the filter seal as the pressure relief valve in the pump would open
Would some debris at one big end cause the seal to blow, I suspect not?
Possible that blasting media keeps jamming the oil relief valve, if so I would expect visible scoring in the relief valve parts,
I would have thought oil reaching the other bearings and camshaft would dissipate the pressure enough.
I asked about the casing codes thinking super tight bearings might seriously restrict the flow.
I assume that Johnny's crank rotated freely with no high spots durning assembly, likewise with the con rods.
Any debris from the vapour blasting needs to be removed so the strip down is worthwhile.
« Last Edit: Today at 09:16:30 AM by McCabe-Thiele (Ted) »
Offline Johny Boy
« Reply #49 on: Today at 05:02:47 PM »
Hi all, again many thanks for all the advice.
I will try to answer the questions posed below:
Ted – My background is a mechanical engineer; however, my engine rebuild experience is somewhat limited. The bike was a non-runner (25 years plus) when I bought it, in fact the front forks were bent so I suspect it had a big front-end shunt in the 80’s and then was garaged after that. Not sure if the cases had been split before, I did not plastigauge, rather I measured the crank journals using a 25-50 micrometer (multiple times) and used the chart in the Haynes manual to spec the replacement bearings shells – Can’t remember what went where now although I do have the codes / locations on the outside of the new shells and hoping someone can translate these for me, they are: D1B, D0B (x2), D0D (x2)
The pressure relief valve was hard to remove, you can’t get behind it to push it out and it took a fair few bangs to get it out. It was assembled in the correct orientation.
I have just checked the relief valve shuttle and there are 2 shiny / smooth areas 180 deg opposed where the shuttle would have been in the pump casting, and corresponding marks in the inside of the pump castings (Photos attached, but it’s hard to get clear ones). It is possible it had bound up here previously
It does now slide in and fall out if I invert it, however I had loosened it before putting it back on and cracking the original oil filter housing.
I plan to put the shuttle up in the lathe and clean it up with some P1200 before I refit it. The inside of the pump housing too
The crank rotated a smooth as silk after I rebuilt it, my mate who has far more rebuild experience than me agreed it was super smooth running. Also smooth after the head/barrels was fitted over the pistons.
I have just checked the oilways from the large transverse oil gallery up to the main bearings (Torch and a dark room) and there are no obstructions in there. [ Guests cannot view attachments ]
I also agree with you and Bryan that even if oilways were blocked the relief valve should have prevented the blow out. I am concerned that I have overtightened the oil filter housing though, TBH I did not use a torque wrench on this and can see radial cracks on the first replacement housing I bought… Got a nice new one waiting for the re-rebuild!
I’m now starting the process of cleaning everything to ensure it has no blasting media left anywhere in it, then I guess I’ll rebuild it and see what happens.
CB550 (85% there)
New BSA Goldstar (my daily)
MV Agusta F4 750 Senna (Front room love affair)
BSA bantam (my constant pain in the arse)
« Reply #50 on: Today at 05:19:54 PM »
Certain reads that you did everything right aside from some post vapour blasting cleaning.
All the best with the next start up.👍
PS You might be aware,  there are some dot markings on the oil pump parts for assembly.
« Last Edit: Today at 05:34:16 PM by McCabe-Thiele (Ted) »
Offline Johny Boy
« Reply #51 on: Today at 05:49:38 PM »
Thanks Ted, Dots on the same side
CB550 (85% there)
Offline scottly
« Reply #52 on: Today at 05:52:31 PM »
Have you checked the compressed length of the spring?
Seeley SH7-521 owned since 1979
« Reply #53 on: Today at 05:58:26 PM »
If you check the outside lower edge of the shell bearings you should still be able to see the colour markings. The stamps on the outside of the shells mean nothing to us, they were just production marks. However IF you find 2 the same it's more than likely they are the same colour, it's working out what the colour is that's the hard part. If however you have a shell where you can see say the green marking and it has D1B on it then any other with D1B will also be a green. Hope that helps.
I've dismantled a few oil pumps off the 500/550 in the last few years and only one had a working pressure relief valve. All the rest were jammed in place. I did a post to warn members to check theirs. I doubt more than a few did however.
« Reply #54 on: Today at 05:59:08 PM »
Must be on the same side and lined up.
Offline Johny Boy
« Reply #55 on: Today at 06:20:29 PM »
The dots don't stay aligned.
4 lobes on inner and 5 on the outer, so it moves around as the pump rotates.
The dots are to ensure the wear pattern stays the same along the length of the georotor faces
CB550 (85% there)
« Reply #56 on: Today at 06:24:54 PM »
Just looked at a couple of oil pumps I still have apart, just to see exactly how they work. I spotted one thing that may help others, bit late for you I'm afraid Johny. If the relief valve is stuck on your oil pump and tipping it on it's side and banging the pump doesn't dislodge it then remove the pump cover, remove the rotors and the gear and shaft. Essentially you'll have a bare pump at this point. You'll see looking inside where the rotors fitted, 2 chambers. One is the incoming chamber from the oil pan, the other on the left side as you look at the pump (correct orientation) is the outlet chamber. Inside the chamber and just visible is the end of the relief valve. You should be able to get a screwdriver or similar and lever it a little, shouldn't take too much to dislodge it enough to remove it. Saves breaking the pump body.
I checked mine and the shuttle moves very easily now it's been cleaned off. It should fall out as soon as you tip the body.
As far as I'm aware the dots were meant to be just on the same side, usually facing outwards so you could see them.
« Reply #57 on: Today at 06:26:45 PM »
My mistake then, I know the dot move around on but I have the dots in line when assembling before putting the cover on.
