Author Topic: Front brake caliper  (Read 1002 times)
Offline robvangulik
  • Honda Fourever
Re: Front brake caliper
« Reply #15 on: November 27, 2026, 08:49:26 PM »
The forks Soichiro gave it, slightly adapted
« Reply #16 on: November 28, 2026, 12:45:55 PM »
Nicely done, looks factory 8)
« Reply #17 on: November 28, 2026, 12:56:12 PM »
So what was involved?
Original forks with welded on fittings or a specialist Honda tuner made setbup?
« Last Edit: November 28, 2026, 01:51:08 PM by McCabe-Thiele (Ted) »
« Reply #18 on: November 28, 2026, 02:41:33 PM »
How about doing what the 500 owners did until the 550 came out and fit a left hand slider onto the right but backwards.
Online Mikep328
« Reply #19 on: November 28, 2026, 03:37:18 PM »
But if a PROPERLY set up OEM brake can lock the front wheel (it can), why bother with such a mod unless the goal is to have dual discs for appearance purposes.
Mine:
1976 CB400F
1973 Norton 850 Commando
2015 BMW R9T
2017 BMW R1200RS
2021 Moto Guzzi V7 Special
Wife's:
2015 Ducati Diavel
2019 Honda Africa Twin
2019 Honda NCT750
Offline robvangulik
  • Honda Fourever
« Reply #20 on: November 28, 2026, 08:08:04 PM »
Some secure measuring followed by a  bit of aluminium welding
« Reply #21 on: November 28, 2026, 08:35:34 PM »
If you work as much on the original sliders from that era you can tell the fittings for the mudguards and calipers were alloy welded originally, not cast into the slider as I originally thought.
« Reply #22 on: November 29, 2026, 12:19:50 PM »
Hi all ,
Has anyone fitted a different front brake caliper to improve the braking ?
One of the difficulties of changing is that these original design have a very slim dimension on the fixed side of the caliper. This is also very close to the spokes of the wheel, making it critical in finding anything that could fit there, that's before the practicality of arrangement in mounting to a unique anchor point of these fork slider.
« Reply #23 on: November 29, 2026, 12:23:58 PM »
As scottly noted in further back post, one simple way to change performance is to change mastercylinder bore (use a different master) to smaller size. This will increase the leverage ratio in hydraulic system to need less effort for same brake torque, the flip side of this is increase in hand travel as consequential balance.
