Author Topic: CB500 four rear wheel bearing retainer  (Read 128 times)
Offline Plammiman
« on: November 25, 2026, 05:45:58 PM »
I need to change out my rear wheel bearings. Is the bearing retainer right or left handed thread?
Offline Neilw
Re: CB500 four rear wheel bearing retainer
« Reply #1 on: November 25, 2026, 05:52:51 PM »
If you need a cheap extractor, this worked well for me.
https://www.amazon.co.uk/dp/B0CNXHPN2B?ref=ppx_yo2ov_dt_b_fed_asin_title
« Reply #2 on: November 25, 2026, 07:05:39 PM »
It’s marked. Goes the opposite way to normal, so goes to the right to loosen it off.
Offline Plammiman
« Reply #3 on: November 25, 2026, 07:36:28 PM »
Thanks for the info saves a lot of guessing
« Reply #4 on: November 25, 2026, 07:58:51 PM »
As has been said it's a left hand thread, might also  be peened if that's the right expression.
« Reply #5 on: Today at 12:50:41 AM »
Yes, should be peened on the threads down the hole, needs drilling out with small drill
