Author Topic: Original side stand  (Read 274 times)
Offline Athame57
Original side stand
« on: November 25, 2026, 08:52:30 PM »
I nearly had another side stand accident recently, once in a while I forget and I bet we all have as well. I do not have the original side stand unless I have one with the rubber foot mounting missing.  :-\
I've had a good hunt, but it isn't even to be found on the CMSL site, so before I go too far into the wilderness hunting this rare bird, is it worth it? Does anyone know if that rubber foot really stops you getting into trouble? I gather it's job is to flick the stand up by contacting the deck first?
1978 CB400F2 named Elen.
Re: Original side stand
« Reply #1 on: November 25, 2026, 09:23:10 PM »
Sorry George but the 400/4 never had the rubber boot, it was just the metal foot. I don't know if the US version had the rubber boot fitted, maybe try eBay and extend the search to the US although if you do find one the P&P and tax will be expensive.
« Reply #2 on: November 25, 2026, 09:25:08 PM »
I forgot to add, my old CB250RSA had the side stand with the rubber boot and yes, I can testify they do work when you forget to flick the stand up!
« Reply #3 on: November 25, 2026, 09:51:32 PM »
Here is the part number George but as Dave says, they weren't fitted on UK models.
50548356700
They fit many models.
https://www.ebay.co.uk/itm/227592760028?mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5339164757&toolid=20006&customid=CjwKCAiAq5rYBhB-EiwAhj1RdsgDjk2JCkOzrcpli9NC_AX9n3BvJn3dC_3QlM8d5D7jumthVBxslhoChjwQAvD_BwE|0AAAAA-V3c3UMXUtvHqV2l-58yOlzyqZzn|Cj8KCQiAiJXYBhC7ARIuADMmXbH1M7z1N_MHFZ0ADu4OkE-8iloXNXFqXyRLeK50xdf7bDxWHUugGYGcmRoCb6E&gclid=CjwKCAiAq5rYBhB-EiwAhj1RdsgDjk2JCkOzrcpli9NC_AX9n3BvJn3dC_3QlM8d5D7jumthVBxslhoChjwQAvD_BwE&gbraid=0AAAAA-V3c3UMXUtvHqV2l-58yOlzyqZzn&wbraid=Cj8KCQiAiJXYBhC7ARIuADMmXbH1M7z1N_MHFZ0ADu4OkE-8iloXNXFqXyRLeK50xdf7bDxWHUugGYGcmRoCb6E&loc_interest_ms=&loc_physical_ms=9046218&adtype=pla&gad_source=1&gad_campaignid=24060400535
« Last Edit: November 25, 2026, 09:53:26 PM by Nurse Julie »
Offline Reborn 400
« Reply #4 on: November 25, 2026, 10:01:31 PM »
AFAIK they were only fitted to German and USA models, but there is one available in Germany, brand new, complete stand with rubber foot...but it's over £100 on ebay.
Offline Reborn 400
« Reply #5 on: November 25, 2026, 10:14:36 PM »
I think the most economical way of fitting one, would be to fabricate a bracket yourself and weld it on. Another alternative is to rig up a switch as found on later bikes, which cuts the ignition if a gear is engaged when the stand is down.
« Last Edit: Today at 12:42:03 AM by Reborn 400 »
Offline Athame57
« Reply #6 on: November 25, 2026, 11:53:37 PM »
I really meant the rubber foot.  ;)
Online badger_eng
« Reply #7 on: November 25, 2026, 11:55:24 PM »
I will be hacksawing the rubber foot / bracket assembly off my CB550 sidestand in a day or three’s time.
Depending on how pretty it looks, it’s yours if you want it.
Bear in mind that preserving the sidestand casting is more important to me than preserving the sidestand “cast off” that I don’t want.
Let me know if you are interested and I’ll up my care level if required.
Current:-
Suzuki GSX-S1000GX+ - 2026
Suzuki GT500A Cafe style - 1976
https://www.kettleclinic.co.uk/kcforum/viewtopic.php?t=14273
Honda CB550K - 1977 (Winter 2026/27 project)
Online badger_eng
« Reply #8 on: Today at 12:05:53 AM »
Taken only 8 hours ago…..
Current:-
Offline Athame57
« Reply #9 on: Today at 12:06:25 AM »
50548356700
Hello Julie
CMSL site is confusing. This is  part of the image they have for the UK model, it seems to feature the rubber boot (foot?) but doesn't list it in the attached price list. I figured they plain didn't have it.
Offline Athame57
« Reply #10 on: Today at 12:10:26 AM »
I'll PM you. :)
Offline Reborn 400
« Reply #11 on: Today at 12:34:50 AM »
Just trying to help, but what is it that you actually want, George?
Some pics of your existing side stand set up might make it clearer.
Johny
Offline Athame57
« Reply #12 on: Today at 03:49:11 AM »
Johny
See the stand in the diagram? Same as that but without the small holder on the side.
« Reply #13 on: Today at 09:22:18 AM »
  "Does anyone know if that rubber foot really stops you getting into trouble? I gather it's job is to flick the stand up by contacting the deck first?"
Absolutely, I've not had much need, so far  :) but they easily flick up an errant stand when forgotten. It can be seen from the habitually forgetful that the rubber wears away from that use and Honda do put a minimum mark on it to check.
I'd never thought much about them when they were being put on bikes at their introduction.  More recently though, a friend had a very serious accident that would likely been contained by this as he'd left the rubber part off (think he renovated/refurbished the bike) with the resulting impact from being hammered into a wall causing significant injury.
That person is hugely skilled and trusted by me as rider and technical expert, his story candid in admission that he'd properly ballsed it up by casual dismissal of something that seemed insignificant at the time.
« Reply #14 on: Today at 09:29:36 AM »
It could be that another bike's stand will fit as the clevis/mount and bolt is carried across many models from when they started putting them on in mid to late 70s.
My early 80s Honda stand is 235mm as example, from bolt centre to foot plane.
Many newer bikes use a switch in series with neutral light, that to cut ignition if you put it in gear with stand down.
