Author Topic: more help please  (Read 11815 times)
pastyman
  • Guest
more help please
« on: April 13, 2011, 07:23:05 PM »
sorry but i have another couple of problems that i hope you can help me with please
1. when i squeeze the front brake the lever is extremely soft, so i thought no probs it just needs bleeding - now here's the problem, as i was bleeding the system i noticed that the wheel was moving does this meen that the wheel bearings are shot
and number 2 is I eventually got the bike running and when i put my hand on the exhaust downpipes i noticed that only 2 of the pipes are getting hot. Now initially i thought that it was one of the coils but then realised that it couldn't be as it was 2 pipes that were adjacent to each other
Now i have replaced the spark plugs, HT leads, and checked the carbs and dont know what else to do
Please help
cheers
pasty
Offline Seamus
Re: more help please
« Reply #1 on: April 13, 2011, 10:07:15 PM »
With the front brake, is the caliper set correctly? It is a floating unit that operates from one side with a pivot to apply the second side. Possibly a seized pivot, Do both sides move when you apply the brake?
As for the engine, which two pots are not working? The carbs are fed in pairs via two petrol pipes. Are these flowing fuel to all the carbs?.
A good place to start
pastyman
  • Guest
« Reply #2 on: April 14, 2011, 06:19:11 PM »
with the brake only one side moves
with the pots - as im sitting on the bike its the 2 that are on the left
« Reply #3 on: April 14, 2011, 09:27:59 PM »
With the brake caliper, If you undo the two bolts holding the caliper together and move the parts out of the way then you should be able to move the arm easily with your fingers on it's locating pivot that's still bolted to the fork. If this is not possible you'll have to free this for the brake to work properley.
If it's siezed too close to the wheel it'll have the effect you've felt in that it pushes the piston too far back into the caliper when released so that too much lever stroke is used to move it into a braking position. It'll also bind when running unused probably.
pastyman
  • Guest
« Reply #4 on: April 15, 2011, 06:08:25 PM »
a1 advice thank you - it was exactly what you had described
with the other fault it appears that somebody broke into my garage and undid the 2 jubilee clips that hold the carbs to the engine  :-[ ;D :-[
« Reply #5 on: April 15, 2011, 08:09:41 PM »
2 clips?
Weren't the other two fixed at all?
 :o
« Reply #6 on: April 15, 2011, 09:34:11 PM »
Nice one and good you've got sorted.
It's surprising how much effect that brake pivot has if sticking, I think the brake is not bad at all for that era if working correctly.
Also if not binding it makes the throttle work better too!!!!!!!!!!!! Ha Ha.
pastyman
  • Guest
« Reply #7 on: May 01, 2011, 08:33:21 PM »
sorry i'm back again with another question, but a simple one hopefully  ;D
i'm still trying to sort out the running probs with my carbs and i think it will all be sorted now as ive ordered a new set of carb to head rubbers
but my question today is what does everyone use to hold the rubbers on because i think jubilee clips are too harsh for this job
cheers once again
« Reply #8 on: May 02, 2011, 09:00:29 AM »
« Reply #9 on: May 02, 2011, 09:02:47 AM »
You need the proper Honda clips as they are narrower than Jubilee, which is why the Jubilee ones dont work well, problem is the clips ain't cheap and dont even come with the screw which has to be ordered seperately so people think oh it dont matter i'll use cheaper jubilee clips but due to the width they dont tighten properly and distort the rubber
Well there you go, Spitfire got there first and DS includes the screw, but you are still looking at
« Last Edit: May 02, 2011, 09:04:57 AM by Bryanj »
« Reply #10 on: May 02, 2011, 09:15:00 AM »
I've got a set that I bought on eBay years ago.
I'll go and see if I can still find them.
Steve
pastyman
  • Guest
« Reply #11 on: May 02, 2011, 10:25:11 AM »
thanks again for your help everyone
i'm going to sound tightfisted now and say i'm going to look elsewhere from D/S because my personall opinion is that although he has the stock, i think he is very expensive for what he does
thanks once again
and to finish off here is a piccy of my bike (purists look away now  ;D)
pastyman
  • Guest
« Reply #12 on: May 07, 2011, 09:03:11 PM »
ARGGHHHHH
new carb rubbers arrived and duely fitted but i still cant get headers 1 & 2 hot
now so far i have
compression test across all cylinder - all equal
stripped carbs completely and cleaned
used a suck ometer (not sure of real name) it tests the amount of air being sucked into carbs
took plugs out 1&2 are spotless 3&4 sooty
adjusted all valve clearences
what else can i do now please as im starting to pull my hair out
cheers
Offline kaceyk2
« Reply #13 on: May 08, 2011, 01:45:04 AM »
take the plugs out of cylinders 3 and 4 and put a bit of fuel down the plug holes, put the plugs back in and see if she fires on those cylinders when you crank it over..if she does, you still have carb issues....sooty plugs are a sign of over rich mixture---- too little air..
try that and report back....
Taking comfort in not owing China 75 Trillion Dollars.
« Reply #14 on: May 08, 2011, 08:42:13 AM »
You think DS is expensive? try going to a Honda dealer!!!
Example
Caliper seal from DS
