Author Topic: removing a dent from a petrol tank  (Read 4184 times)
MIKE550/4
« on: May 31, 2011, 08:51:37 PM »
550 tank
anyone have any experience with pulling. removing a dent , tank is to stripped and resprayed
do not want to fill it
thanks
Offline kaceyk2
Re: removing a dent from a petrol tank
« Reply #1 on: May 31, 2011, 11:35:06 PM »
one way to do it, ( there will be others) is to tack weld a home made draw hammer on. ("T" bar with sliding weight)  Or tack braise it on.  draw out the dint, and then untack the draw bar.
That will get you a result that will require the absolute minimum of filling.
A small "skim" of filler should not be a problem?
Taking comfort in not owing China 75 Trillion Dollars.
