CB750
Rear hub CB750/500
Topic: Rear hub CB750/500 (Read 4289 times)
RupertB
SOHC Associate
If a hammer won't fix it, then it's electrical.
Rear hub CB750/500
June 04, 2011, 09:03:36 PM »
Anyone know definitively if a CB500 rear hub is the same as or interchangeable with a CB750 - or is the 750 heftier to cope with power/weight etc?
Author of 'Prisoners Property and Prostitutes' by Tom Ratcliffe. You'll enjoy it and I need the money.
ST1100
Re: Rear hub CB750/500
June 04, 2011, 11:03:03 PM »
I would compare the part numbers:
http://www.cmsnl.com/honda-cb-four_model7148/
STOC #637
Voxonda
SOHC Member
June 05, 2011, 09:49:31 AM »
They are definitely not the same.
Better sorry for failing than for the lack of trying.
RupertB
SOHC Associate
June 05, 2011, 05:05:29 PM »
Thanks folks - had a feeling they might not be, but better to ask than guess - either way!
June 06, 2011, 07:19:01 AM »
750 different shoes and totaly different cush setup/sprocket carrier
CB750
Rear hub CB750/500
