front mudguard mounting 550f2
Topic: front mudguard mounting 550f2 (Read 6582 times)
kendo57
SOHC Associate
June 26, 2011, 09:06:20 PM »
Can someone tell me if the left mudguard mount fits behined the brake swivel bracket
or bolts to the top of it.
Looking at pictures in my old manual [cb500] it looks to bolt between the forkleg and
brake bracket but i am sure on mine it was bolted to the outside of the bracket.
florence
Re: front mudguard mounting 550f2
June 27, 2011, 09:08:49 AM »
It should be behind, i.e, next to the fork leg, then bracket on top of it.
kendo57
SOHC Associate
June 27, 2011, 11:07:43 AM »
Thanks, it looks like the previous owner has bent the bracket and fitted to the outside.
SteveD CB500K0
Administrator
Ride on the Steel Breeze...
June 27, 2011, 02:35:11 PM »
I've just checked on mine and Steve (Florence) is correct.
If yours is the other way round the movement of the front brake caliper must be compromised (?)
florence
June 28, 2011, 11:09:52 AM »
Oh my golly gosh, I've just looked at mine and you are correct. The mudguard is on the outside. Humble apologies
kendo57
SOHC Associate
June 28, 2011, 10:43:38 PM »
Well the way the bracket is shaped it looks like it should go on the outside and
i have found a picture in the CB500 manual showing it on the outside.
So i think Oddjob has now convinced me the outside is the way to go.
Thanks again.
