Author Topic: Battery not charging  (Read 4177 times)
Offline stubobaloo
« on: December 12, 2011, 03:22:45 PM »
This is a simple one for all you highly tuned mechanical types.. but first off I have something to own up to.
I made the mistake of thinking because my bike was built in 1976, that made it a K6. Apparently, according to some sharp-eyed fella on Ebay it's a CB750F.
Anyhow, the battery ain't retaining a charge.... any clues ?
Thanks for any assistance, much appreciated
Stu
Re: Battery not charging
« Reply #1 on: December 12, 2011, 03:56:15 PM »
Have you had a look at it? is the fluid within levels on all cells? Chances are if it aint holding charge, it's probably knackered! The usual answer is to replace it, they are relatively cheap (
« Reply #2 on: December 12, 2011, 09:38:26 PM »
Post a picture of your bike.
Offline Seamus
« Reply #3 on: December 12, 2011, 10:31:41 PM »
As above, but may be worth putting a multimeter accross the battery terminals and seeing what voltage you get, with out the engine running and then with.
« Reply #4 on: December 13, 2011, 06:41:20 AM »
Normal none charging problem is bad connections.
read  http://data.sohc4.net/Tech/HondaMES/HondaMES3.PDF
to understand how the system works, the tests for if its charging are in the manual
Offline stubobaloo
« Reply #5 on: December 13, 2011, 03:00:12 PM »
...thanks all.. pic attached by the way...
« Reply #6 on: December 13, 2011, 03:07:10 PM »
Looks like a CB750F, from the back brake assembly, headlamp etc but not an F tank.
Den
