Author Topic: Exhaust Stub cross head screw removal  (Read 5262 times)
Offline r1_pete
« on: February 24, 2012, 12:01:30 PM »
I have a K2 engine with the cross head screws holding the exhaust stubs in, they look lik ethe type of screw which are a real pain to get out, anyone have any tips?
Also, once removed, does anyone know if F1 pipes will fit?
« Last Edit: February 24, 2012, 03:42:26 PM by r1_pete »
2009 Yamaha XJR1300 sold
1977 CB750F2 café racer project. Sold
1972 CB750K2 hot rod. Sold
and an E-Type Jaguar that considers itself worthy of all my spare cash. Sold
1971 CB450
1978 Reliant Scimitar Cosworth.
Offline hairygit
Re: Exhause Stub cross head screw removal
« Reply #1 on: February 24, 2012, 12:28:50 PM »
A decent impact driver generally gets them moving, ;D make sure the driver bit is a good fit in the screw, 9 times out of 10 they'll loosen quite easily, DON'T be tempted to try ordinary screwdrivers, as if the screwhead gets damaged/ chewed, then the problems really start :'(
Offline mick
« Reply #2 on: February 24, 2012, 01:39:54 PM »
Hi Pete i've gone the opposite way and fitted stubs onto a F1 engine with no problems so you should be able to fit an F1 exhaust on there but you will need the
exhaust studs and colletts, cheers Mick.
Offline r1_pete
Re: Exhaust Stub cross head screw removal
« Reply #3 on: February 24, 2012, 03:44:47 PM »
Cheers guys, I can make the studs and collets, I just like the look of the F1 4-1, its goimng to finish up quite a bitsa, F2 Chassis, K2 engine, F1 exhaust......
Off to machine mart now for an impact driver.....
1971 CB450
« Reply #4 on: February 24, 2012, 05:27:32 PM »
I've got a set of collets.
I don't know what they're from (other than that they're off a 750...) but you are welcome to them for the postage cost if you want them.
There are 8 of them.
Offline mick
« Reply #5 on: February 24, 2012, 08:48:41 PM »
They look like 750 F1 Steve  ;) cheers Mick.
« Reply #6 on: February 24, 2012, 09:52:06 PM »
The title of the picture is a bit of a giveaway...
« Reply #7 on: February 27, 2012, 09:58:32 PM »
Just to add to the other advice already given, I start by using a broad faced punch (you can use an old socket extension bar) to "peen" the edges of the cross into the gaps slightly. Then if you get the impact driver bit on it's own you can tap it into the screw to get a really good tight fit. Finally fit the impact driver and wallop it with club hammer to make it move before you loosen the fit at all.
As the others have said, these usually don't give too much of a problem as long as you don't round them out.
