Author Topic: Rocker arm removal  (Read 4248 times)
Offline pauliexjr
Rocker arm removal
« on: May 11, 2012, 09:26:53 AM »
Is it possible to remove the rocker shafts on a SOHC motor to examine the cam and rockers without taking the whole top end apart? If so how please?
DO NOT BELIEVE ANYTHING YOU SEE OR HEAR ON THE INTERNET - Abe Lincoln 1857
Current
1980 CB750 dohc - a new headache in my life :-)
Previous
1977 CB750 cafe racer, gone but not forgotten!
CBR1000
Yamha XJR1200
Triumph T140V Bonnie
Yamah XV750 Trike
Triumph T110 Saint
Suzuki GT750 'kettle'
Suzuki GT550
Honda CB550
Honda CB175 (first bike)
Offline mick
Re: Rocker arm removal
« Reply #1 on: May 11, 2012, 11:24:51 AM »
You will have to take the engine out of the frame first, then take off the rocker cover,
then undoe the tappet adjusters fully now you should be able to get one side rocker shafts and arms out for inspection ,
i can't remember if you can do both sides at once or if you have to do one side then put it back together to do the other side?,
you may have to rotate the camshaft to undoe the other side? hope this helps cheers Mick.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: May 11, 2012, 05:49:14 PM »
If it's a 750 see the above. If it's a smaller CB this can be done in frame.
