CB750
750 F2 lower engine bolt ?
Topic: 750 F2 lower engine bolt ? (Read 6809 times)
bluemouse1006
SOHC Member
July 20, 2012, 05:56:03 PM »
Hi I'm in the process of fitting a rear disc etc on my K5 ive found that the bottom engine bolt , The one that runs through the front foot pegs is too short the one I have any one have a F 2 bottom engine bolt hanging about I'll pay including postage
Amos
Amos
Re: 750 F2 lower engine bolt ?
July 21, 2012, 12:42:24 AM »
Whats wrong with a length of stainless studding and a nut on each end?
bluemouse1006
SOHC Member
July 21, 2012, 08:23:21 AM »
That's how mine is already but not long enough I wasn't aware you can buy such a thing I'll have a word at my local nut and bolt people ..
Thanks again
Amos
Amos
archmill
SOHC Member
July 22, 2012, 11:33:10 PM »
Bluemouse, just noticed your posting. Still need an F2 engine bolt? I have one you can have for the price of the postage mate.
Archmill
bluemouse1006
SOHC Member
July 25, 2012, 04:11:16 PM »
Still need one thanks let me know what the cost and I'll pay via PayPal or how ever u want I'll send u my address as well
Thanks again
Amos
Amos
archmill
SOHC Member
July 25, 2012, 11:40:23 PM »
Amos, will hunt it out tomorrow.
Archie
bluemouse1006
SOHC Member
July 26, 2012, 01:26:01 AM »
Archie
your a star my address is 37 HU129PJ, surname Goldsmith
thanks again for your help
Amos
Amos
archmill
SOHC Member
July 26, 2012, 11:00:05 PM »
Amos, looked out the engine bolts. The long bolt that is the rear lower engine bolt that also bolts on the footrest bracket is M12 x 430mm threaded both ends. Is this the one you need?
The other two engine bolts are M10 x 280 and M10 x 316.
Archmill
bluemouse1006
SOHC Member
July 27, 2012, 01:25:06 AM »
This is the one the long one that goes through the bracket and the foot pegs bolt to
Amos
Amos
stewonepot
Newbie
July 27, 2012, 02:03:18 PM »
hi amos,
I have a brand new bolt that I got from a firm in somerset for £10 that you are welcome to.The problem is the postage as I live in southern spain let me know if this helps or not.
stewonepot.
bluemouse1006
SOHC Member
Reply #10 on:
July 27, 2012, 04:15:00 PM »
Stone pot
Thanks for the kind offer ill keep you in mind
Amos
Amos
stewonepot
Newbie
Reply #11 on:
July 27, 2012, 04:45:35 PM »
amos,
No probs, good luck with the build.
stewonepot
archmill
SOHC Member
Reply #12 on:
July 27, 2012, 11:25:24 PM »
Amos, I have checked the part numbers for both the K5 and F2 bolt and they are totally different. I would go for stewonepot's offer as I guarantee the F2 won't fit ( otherwise the part number would be the same )
Archmill
bluemouse1006
SOHC Member
Reply #13 on:
July 28, 2012, 03:34:33 AM »
Hi
Im changing the full rear set up tor a F2 with the large alloy frames etc that the bolt goes through so yours should be ok i think ?
any news on the wheel ?
Amos
Amos
stewonepot
Newbie
Reply #14 on:
July 28, 2012, 06:38:51 AM »
hi amos,
i'm abit grogy from last night's olympic drink up, but if you are going for the full f2 foot peg set up I have the lot. It comes from an extra frame that I have here from a germany f2. It includes the rear master cylinder( which needs new seals) as I said before not needed now so small££ and cover the postage
kind regards Stew
CB750
