Author Topic: Points screws  (Read 4617 times)
Offline Waggles
Points screws
« on: August 06, 2012, 07:22:58 AM »
Anyone happen to know what size the ikkle screws that hold the points on and the 2-3 timing adjust are? Guess my P.O. got a bit hungry and chewed em a bit, they are useable, ( just ) but I would like to replace them with cheese head ones. ( I have an aversion to cross heads, dunno who thought they were a good idea, seem to be designed to chew up asap ) they don't seem to be listed on parts lists to give me the size, I can measure thread diameter but the pitch looks a bit fine to me.
Re: Points screws
« Reply #1 on: August 06, 2012, 08:10:40 AM »
My geriatric parts book (matches me!) sez 93500-05012OA SCREW, flat 5x12 quantity 3 BUT i have a feeling those are the 3 that hold the assembly to the crankcases.
If its what i think you mean there is no part number all you can do is match them at a supplier, by the by I never liked allen screws in there as its too easy to overtighten and strip the threads
Offline Waggles
Re: Points screws
« Reply #2 on: August 06, 2012, 11:02:40 AM »
Thanks Bryan, yes they are the ones that hold the back plate, and I've replaced them. I agree re: allen heads, would only use them if I had to, I would prefer cheese heads if I can source some or the originals as they have a slot as well as cross head.
Will measure them up as best I can and see what I can come up with
62tt
Re: Points screws
« Reply #3 on: August 06, 2012, 07:50:13 PM »
All the threaded holes in the points back-plate are M4 (M4 x 0.8 to be exact).
Offline Waggles
Re: Points screws
« Reply #4 on: August 07, 2012, 09:45:48 AM »
I'd better measure again then Nick, I measured a screw by eye and ruler and made it M3 X 6mm better get the vernier calipers out!
Offline Seamus
Re: Points screws
« Reply #5 on: August 07, 2012, 12:24:24 PM »
Sorry to add confusion, but I measured them at M4 x 0.7.
They are shown in the parts diagram, but not listed with part numbers.
Could be me or the guages. Best bet is a decent fastener outlet. Bring the old ones down and get therm matched. you can then post the correct sizes for the rest of us.
62tt
Re: Points screws
« Reply #6 on: August 07, 2012, 09:48:12 PM »
Sorry for the confusion too, Seamus is spot-on, they are M4 x 0.7 which is standard metric thread, (I need more sleep, I was thinking of M5 pitch)!
