CB750
Headlight bulbs
Topic: Headlight bulbs (Read 4676 times)
Waggles
SOHC Expert
Headlight bulbs
August 31, 2012, 07:10:50 AM »
I have a standard headlight and the bulb just blew ( and its only 36 years old, rubbish I call it
) strangely I have another 70's one I can replace it with for now but don't expect that to last long either.
What does everyone else use and where do you get them? I am not after upping wattage, standard will be fine as I won't be doing any dark country lanes and I ride on dipped beam all the time. Haven't actually seem the standard bulbs anywhere so do you have to switch to H4 Halogen?
Re: Headlight bulbs
August 31, 2012, 07:41:12 AM »
You should still be able to get bulb from any Motorcycle shop, it was a standard fitting used not just on Honda's and was available in 6 and 12 volt(Don't get the wrong one----yes it will be bright but only for 2 seconds!!)
Spitfire
Re: Headlight bulbs
August 31, 2012, 08:57:29 AM »
Think mine came from David Silvers, not sure though
Re: Headlight bulbs
September 02, 2012, 06:27:06 PM »
Update:- had my running 500 MOT'd Saturday---yes of course it passed(I'd be in deepest do-do if i had one fail!) and asked at the dealers i used and he said got 'em on the shelf as they fit lots of bikes
Waggles
SOHC Expert
Re: Headlight bulbs
September 03, 2012, 07:14:05 AM »
Thanks Bryan.
Most of the dealers near to me only have brand new bikes 'on the shelf' so to speak and look at you with a worried expression if you imply you are going to actually touch your bike yourself!
thankfully there is one 'proper' old fashioned bike shop in Southend, I will pop in there when I get a chance.
Waggles
SOHC Expert
Re: Headlight bulbs
September 04, 2012, 07:13:31 AM »
Update, found some on line too at:
http://www.autobulbsdirect.co.uk/410-P45t-Headlamp-45-40W-Older-type-H4-fitting.html
mickwinf
Re: Headlight bulbs
September 04, 2012, 09:21:52 AM »
any car accessory shop would have these, the part numbers are fairly standard, 410 for non halogen, r12 for halogen version. the later halogen type with three locating tags is part no 472 again easily obtained
Re: Headlight bulbs
September 04, 2012, 06:01:46 PM »
Except that that is not the standard fitting in a honda reflector
CB750
Headlight bulbs
