Author Topic: frame paint  (Read 8195 times)
Offline ianmck
frame paint
« on: September 11, 2012, 08:33:58 PM »
I am cleaning up my 750 K4 frame, do not want to p/coat, anyone got any experience of a good , durable paint to use, at the moment thinking of satin black hammerite. Any thoughts would be welcome. Thanks in advance. Ian.
1977 400/4 supersport.   1973 cb750 K4,
Offline matthewmosse
Re: frame paint
« Reply #1 on: September 11, 2012, 09:38:59 PM »
Blackfriar red oxide and black enamell, takes 4 coats but seems to have lasted better than hammerite on my bikes. Cheaper too.
Offline billy192
    • Shermonkel
Re: frame paint
« Reply #2 on: October 19, 2012, 10:08:54 AM »
Hi Ian,
I am new to this restoration stuff but why not p/coat? i thought powder coat was a good base.
Billy
Billy
Offline LesterPiglet
  • 1977 CB550F2
Re: frame paint
« Reply #3 on: October 19, 2012, 11:43:42 AM »
Don't use Hammerite/Smoothrite, it chips so easily. I know this.  :-\
'Then' and 'than' are completely different words and have completely different meanings. Same with 'of' and 'have'. Set and sit. There, their and they're. Set/sit. Bought/brought FFS. Bloody Americans.
Les Ross. Certified by a Professional
Offline ST1100
Re: frame paint
« Reply #4 on: October 19, 2012, 12:52:32 PM »
... why not p/coat? i thought powder coat was a good base.
There risks of creating pockets/cavities (i.e. on/around welding seams and/or other not 100% clean surfaces) in which corrosion takes place; unseen at first, by the time the dense plastic layer finally cracks open the damage to the steel underneath can be severe...
(as with Teroson undercarriage protection on vintage cars... )
BTW: anyone treating also the inside of the frame tubes, like with Waxoil or such?
STOC #637
Offline tom400f
Re: frame paint
« Reply #5 on: October 21, 2012, 10:19:01 PM »
So if painting, what methods of application do people use?
Put another way, can you get a decent finish with a brush or do some of you have an air line etc?
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
Offline mick
Re: frame paint
« Reply #6 on: October 21, 2012, 11:29:02 PM »
Hi Ian believe it or not but i have had excellent results using non drip gloss  ;), using decent stuff like Dulux,
obviously the preparation is very important and using a decent undercoat to, only trick i use is don't paint in direct sunlight dries your paint to fast and causes drag= brush marks,
i usually hang my frames up and paint the frame in one go  ;), don't know how many frames i have painted but its alot , i've also painted a Mini Van, Transit Pick up, Transit Van, and a Cortina Estate , cheers Mick.
Offline Ewan 500 K1
  • jings crivens help ma boab
    • Adams Bros Probe 2001
Re: frame paint
« Reply #7 on: October 21, 2012, 11:41:24 PM »
I tried woodchip once, but wouldnt recommend it .... gets a bit soggy and peels off  ;)
500K1/550K3 mongrel cafe racer project for now at http://www.sohc.co.uk/index.php/topic,4120.0.html
500K1 basket case for later
Re: frame paint
« Reply #8 on: October 22, 2012, 06:34:13 AM »
Artex is a bugger too
Offline Green1
Re: frame paint
« Reply #9 on: October 22, 2012, 06:08:52 PM »
I always use a brush as you put more paint on.
Key the surface first then use Hammerite special metals primer and then two thin coats of rustoleum gloss black.
If you prep well first than you get a brushstroke free finish and it looks as good as powdercoat.I wouldn't recommend household undercoat and gloss anymore as they have messed with the formulas and they are now crap and take weeks to harden up.
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline mick
Re: frame paint
« Reply #10 on: October 22, 2012, 08:22:28 PM »
I did most of my frame and car painting in the late 80's /early 90's when paint was proper paint not this wishy washy crap you get nowadays  :o,  ;) cheers Mick.
« Last Edit: October 22, 2012, 08:47:40 PM by mick »
