Author Topic: Gasket Q ??  (Read 3390 times)
Offline cb750stu
Gasket Q ??
« on: October 05, 2012, 06:56:58 PM »
Hi folks I'm going need to replace my oil pan gasket as it is leaking. I have noticed that there is some kind of orange rubbery material dotted around the seal ????
My Q is should I just put the new gasket on without sealant or use sealant I know gaskets are designed to go on without sealant !!!
It will also be a good chance to check the oil strainer !!!
Anybody know what torque setting I should use for the bolts ??????
Regards, Stu
1976 CB750 F1 SS in bits !!! but getting there
Offline LesterPiglet
  • 1977 CB550F2
Re: Gasket Q ??
« Reply #1 on: October 05, 2012, 08:16:50 PM »
Is the 750 the same as a 550 as far as the gasket sits in a groove? If not ignore this.  :D
That orange goo should not be there as it could detach and block an oilway. Make sure you clean it all off.
Really a new seal should be used but I've never replaced mine. I usually put a tiny line of sealant (gasp) in the gasket groove, just enough so it doesn't squeeze out when you put the gasket in.
« Last Edit: October 05, 2012, 08:18:59 PM by LesterPiglet »
Offline bluemouse1006
Re: Gasket Q ??
« Reply #2 on: October 05, 2012, 08:22:07 PM »
Stu
Be careful with sealant on the 750 engine as they really don't like sealant and block the oil ways to the head
Amos
Amos
Offline cb750stu
Re: Gasket Q ??
« Reply #3 on: October 05, 2012, 08:37:54 PM »
Cheers folks I have a new genuine gasket to put on I'm not going to use sealant never liked using it,
How does the oil strainer come out ???
Regards
Offline cb750stu
Re: Gasket Q ??
« Reply #4 on: October 05, 2012, 09:49:52 PM »
There wasn't even a gasket on the oil pan just a bead of orange goo oil strainer was very clean aswell nothing in it !!
